R52 Transmission Problem in 06 S Conv.
Old Nov 16, 2013 | 06:53 PM
minicooperlover22's Avatar
minicooperlover22
So today as I was pulling my moms 2006 Cooper S. Conv out of a parking space in best buy and as I was selecting drive, the car jerked a little and went into EP mode and when I parked it it jerked as I put it into park. And as we drive, it makes a noise, it's very hard to describe, I believe it's the supercharger going out, but I'm no expert I also thought flywheel too. It has 96k on it
Edit: here's the link for the noise
Old Nov 17, 2013 | 05:05 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Sounds like you have an automatic (Non-CVT) since you stated that you "selected drive"...so doubt it's an automatic flywheel problem. I have not seen that to be an issue with the GA6F21WA transmission.
But could be a fluid ( JWS 3309 ) level issue or problem with the Control Unit related problem. Part #1 below.
Ever have the system flushed and filled ?
Old Nov 17, 2013 | 09:33 AM
ZippyNH's Avatar
ZippyNH
Best buy?! They still open? Buy the Extented warrenty?....on the car...not on anything at best buy that is...lol...
Notice any smells? Any engine lites? Don't think a sc failing on an auto will cause a transmission error code.....
I second the thought...tranny ever been drained/filled....
Kinda wonder if the crank damper Made the sound....that is why I was wondering about the smell...
Any chance of describing the sound? Stuck starter motor? Grinding? Screeching?
Old Nov 17, 2013 | 12:21 PM
minicooperlover22
The 100k stuff was all just done this past July so it shouldn't be a fluid problem... I disconnected the battery and let it sit overnight so I still have to see if it's still in EP mode
Old Nov 17, 2013 | 01:44 PM
-=gRaY rAvEn=-
Moderator
"100K mile stuff" = yes, it was done ?
Wasn't aware of a specific 100K flush/fill.
If it was, and still transmission related, then I am hedging towards the Control Unit Replacement. If so, be sure to have the transmission filter changed as well.
Old Nov 17, 2013 | 01:47 PM
ashchuckton's Avatar
ashchuckton
According to MINI your mom's MINI has lifetime fluid. It is highly doubtful anything was done with the fluid. Get it changed now & cross your fingers. Good luck to you & your mom.
Old Nov 17, 2013 | 02:26 PM
minicooperlover22
Good news! I recoded a video! Here's the link
Old Nov 17, 2013 | 02:58 PM
minibx's Avatar
minibx
In order to get better help from the community, see if you can get your hands on a list of what was done to the car to get a better idea on what to look for.
I wouldn't use the word " shouldn't " when it comes to MINI dealers assuming that it was done there
Old Nov 17, 2013 | 05:47 PM
fishbulb's Avatar
fishbulb
Sounds like the beginnings of transmission problems.
lalroma
20
Apr 2, 2022 06:19 PM
mellocooper
R55 :: Clubman Talk (2008+)
Jul 21, 2016 05:05 PM
MiteyF
Aug 26, 2015 05:07 PM
robbiedowns22
Aug 25, 2015 12:20 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
