R56 2007 mcs tpms
Old Oct 14, 2013 | 02:04 PM
arm88's Avatar
arm88
2007 mcs tpms
Hi all,
This is my first post in the forum, so forgive me if there is any mistake.
I don't know if you guys have talked about this topic, but I couldn't find any related information through search option.
Okay, I have 2007 MINI Cooper S. A couple months ago, I upgraded the rims to 18" JCW R113 with tire size 215/40 R18, ditching Run Flat tires. In couple weeks, the TPMS warning came on after I drove in highway for 30 miles or so. I stopped and the checked tire pressure, I found everything okay and reset the TPMS.
Lately, the TPMS come on almost everyday. I use the car to commute to work. In the morning it comes on, and the way back it does too. All this time I thought this car had TPMS mounted on the rims. Since I saw some article saying that TPMS can last up to 5 years or so, my guess was the TPMS need to be replaced. So, I took it to local tire shop. They told me the sensor in this car is integrated to ABS system, not mounted to the rims. My wheels got rubber stem.
I tried to google this issued, but most of the result is rim-mounted TPMS. Any one has solution to this problem? Any information would appreciate.
Old Oct 14, 2013 | 02:42 PM
InjectedGT's Avatar
InjectedGT
Make sure pressures are uniform all the way around and reset it. I have never had it come back on after I reset it, and I run different pressures front and rear. It might be something wrong with the system itself.
hexproject
Sep 7, 2015 08:23 PM
DrFraserCrane
Aug 30, 2015 01:11 PM
BowserKart
Tires, Wheels, & Brakes
Aug 20, 2015 01:24 PM
mini-medic
Aug 18, 2015 09:13 AM
fm.illuminatus
Aug 10, 2015 12:15 AM
