R56 2012 MC oil loss?
Old Oct 13, 2013 | 01:20 PM
grips03's Avatar
grips03
2012 MC oil loss?
non issue, measured wrong
Old Oct 13, 2013 | 02:07 PM
ZippyNH's Avatar
ZippyNH
Out the tail-pipe....MOST LIKELY
You are VERY LUCKY....check your oil!!
Look For Leaks....but many mini's burn a bit...or lots..
Old Oct 13, 2013 | 02:47 PM
maxmini's Avatar
maxmini
Mini says burning a quart of oil within 1,000 miles is within spec , as dumb as that sounds.
Old Oct 13, 2013 | 03:11 PM
DneprDave's Avatar
DneprDave
Most manufacturers say a quart of oil / 1000 miles is alright. Lincoln Mercury said that years ago, when I worked there as a mechanic.
Dave
Old Oct 13, 2013 | 06:59 PM
maxmini's Avatar
maxmini
Dave
And until Honda came along years ago getting 100k out of a car was really something special. So you are telling me the thought of adding a quart of oil to your car every third fill up should be normal ?
Old Oct 14, 2013 | 07:10 AM
DneprDave's Avatar
DneprDave
Yes.
And you should be checking your oil every fill up, just to keep track of it. That's not just for MINIs, but for every brand of car.
Dave
Old Oct 14, 2013 | 07:23 AM
kyoo's Avatar
kyoo
that's.. not normal.
i had an 08 with 95k, never lost a drop
Old Oct 14, 2013 | 07:56 AM
DneprDave's Avatar
DneprDave
You may not agree with it, but one quart of oil used per one thousand miles is an industry standard for maximum acceptable oil consumption.
Dave
Old Oct 14, 2013 | 08:06 AM
kyoo's Avatar
kyoo
Dave
i understand that's industry standard.
now, i'm saying none of my cars ever consumed a drop unless there was something abnormal, especially for a newer car. that includes anything from a 400+whp evo, a ~300whp evo, an 08 mini, an 07 corolla with 166k miles, 94 impreza, 04 outback, '13 outback, '13 camry, '12 honda fit, '03 civic, a few more down the line.
lol one quart per 1000 miles.. the only car i wouldn't be worried for that kind of oil consumption is a car with a rotary engine. it may be industry standard but that doesn't mean something's not wrong. it's just "okay" in the sense that, add a quart every 1k miles and the car will continue to run just fine. a normal car, especially a fairly new one, should not consume any oil, period. unless by design, like an rx7 or rx8.
i think we're playing with semantics slightly here - CAN a car consume 1qt/1k miles (and be fine)? yea, sure. SHOULD it? no, not a newer car, especially one that doesn't necessarily have a history of doing so
Old Oct 14, 2013 | 09:12 AM
Teufel8's Avatar
Teufel8
Oil Loss
My 2000 BMW M5 burned about 1.5 Quarts every 1000 miles or so. I drove that baby hard.
The performance engines have a higher compression, which sucks in more oil and burns it off. Turbo spool rotates at upwards of 200,000 RPMs, oil necessary to cool it and lubricate it.. All depends on how you drive it.
I drive my MINI Wide-Open-Throttle very often, and I know I burn about a 0.75 of a quart every 1,000 miles.
When I was deployed, my wife drove it about 4,000 miles and upon my return, to my surprise, no oil needed to be added.
I am convinced it is how it is driven..
Old Oct 14, 2013 | 09:57 AM
maxmini's Avatar
maxmini
Dave
An industry standard to keep the warranty claims down . It would be a interesting show of hands as to how many people check their oil level with every fill up . I do agree that r56 owners should but that's not a good thing .
With all this oil talk I did to check the family cars and the old escort with 160,000 on the clock was down a half quart from the last oil change 4200 miles ago, the r53 none needed nor any for the wife's Lexus .
When I relocated to CA back in 78 I drove my 71 ford econoline with a 302 from CT loaded with everything I held dear at the time packed in in with a MX bike on the back bumper and towing a trailor with my classic mini which was also packed with my " valuables "
3600 miles of towing , 125,000 miles on the clock and I burned 1/2 quart.
Just sayin
Old Oct 14, 2013 | 12:23 PM
nine5raptor's Avatar
nine5raptor
I change the oil 1x per year in my envoy xl (6-8000 miles) and never have had to add even a half a quart. The ONLY car I've had to add oil to between changes was a jetta. Never on mustangs, jeeps, a talon, taurus, cavalier or a corolla. The MINI (2010 S) is always drinking oil. And I drove everyone of those other cars hard. Crawling in the jeep and 23psi daily on the talon awd.
Old Oct 14, 2013 | 02:51 PM
teamrodney's Avatar
teamrodney
My European spec JCW with N14 engine uses no noticeable amount of oil between 5000km oil changes. very happy with that.
Old Oct 14, 2013 | 05:35 PM
JC07mini's Avatar
JC07mini
Dave
"Most Manufacturers Say"?? Citation needed.
FYI. I'll bet that I've been driving cars longer than you have been alive. Burning a quart every 1000 miles is BAD! And I have a 1991 Mercury with a big 5.0 V8. It still doesn't use a quart of oil per 1000 miles.
And as far as the Mini goes, if it isn't burning out the tailpipe check the vacuum lines. Bet they are full of oil. Put that puppy on a lift and check out the underside.
Old Oct 15, 2013 | 02:17 AM
ocluck's Avatar
ocluck
There was a recall done on the solenoid valve for some MINI 2011+. Mine was losing a little oil that I thought was normal but the recall fixed the issue.
Old Oct 15, 2013 | 05:43 AM
ZippyNH's Avatar
ZippyNH
I wonder what's the op's mpg was?????
Mpg???? Can surmise break in or how hard its been driven maybe...or maybe a stuck pcv valve...it happens....
Op are there??????
Old Oct 15, 2013 | 11:59 AM
Slave to Felines's Avatar
Slave to Felines
I've seen it in the owner's manuals of several different Porsche models. All, however, were the old air-cooled ones.
I personally would be quite worried if my car were burning 1 qt/1000 miles. It may be "allowable", but I don't think of that as "normal"...
Old Oct 15, 2013 | 12:36 PM
DneprDave's Avatar
DneprDave
You can Google it as well as I can.
Dave
Old Oct 15, 2013 | 04:56 PM
danjreed's Avatar
danjreed
I'm with Dave.
I've worked for Ford.. 1,000 miles / Quart is pretty average.. I think VW Audi is the same. I remember seeing the TSB..
Old Oct 20, 2013 | 09:54 AM
grips03's Avatar
grips03
found my error, I drained motor oil and then measured with 2 quart container vs using my 1 quart, So car had 4 quarts plus the little bit in filter
Old Oct 20, 2013 | 10:03 AM
kyoo's Avatar
kyoo
please update the first post as well
Old Oct 20, 2013 | 11:16 AM
RSchleder's Avatar
RSchleder
Checking the oil right with the dip stick before you drain it is another check and balance!
Kimolaoha
Jul 5, 2023 01:04 PM
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
FrostyFox
Oct 28, 2015 02:06 PM
cargusjoh
Aug 24, 2015 07:27 PM
F16poopflinger
Aug 18, 2015 11:25 AM
