R56 Weird sound after engine shutdown
Old Oct 10, 2013 | 11:12 PM
slayerx02's Avatar
slayerx02
So I've had this '11 mcs for 3 weeks and now it makes a weird sound after I shutdown the engine. I've searched around and I've seen threads that suggests it is the water pump going bad. Now my sound doesn't sound exactly like the videos posted here so i thought is post up my own video and get some opinion if this sound could be also be the water pump.
Old Nov 10, 2013 | 08:02 AM
PParker74's Avatar
PParker74
I have a very similar sound in my 2011 S. This is my second Mini the first one a non turbo. Both of them made the same noise when shutting the engine off. I can't tell you what it is but not to be alarmed. Minis in general are very quirky cars it is not unusual to hear strange noises from time to time. Most of the time when something disasters is accruing the computer will already be alerting you. Are you still under warrantee? If so stress your concern with the dealer on your next oil change.
Old Nov 10, 2013 | 08:14 AM
nine5raptor's Avatar
nine5raptor
Check this link. Sound is a little different but happens under same circumstances.
https://www.northamericanmotoring.co...ering-off.html
Old Nov 10, 2013 | 08:42 AM
new07mcs's Avatar
new07mcs
I have an 07 MCS that was making that same noise after every shutdown. Ended up taking it to the dealer and it was the boost solenoid. The part was about 80$ If I remember correctly. Not sure how much labor would be because they were replacing my valve cover as well and didn't charge me to change the solenoid.
Edit: didn't see the video from the op. My noise was the exact same as the video in the post above
Old Nov 10, 2013 | 01:05 PM
slayerx02's Avatar
slayerx02
I took the car to mini north Scottsdale and they diagnosed the water pump to be the one making the sound so they replaced it under warranty (I got 3k miles left). Turns out the sound is coming from something else, like some sort of actuator motor. Not sure what it is but it comes on when I cycle the ignition between I & II.
Fortunately it doesn't sound like the boost solenoid in the video above.
Doesn't sound like anything I should worry about but I will bring it up again just in case when I ask about the timing chain chatter I'm hearing. So close to the end of manufacturer warranty...I wanna make sure I get some use out of it as the second owner.
David.R53
Sep 1, 2015 06:49 PM
makg
Aug 21, 2015 02:49 AM
damncajun
Aug 17, 2015 08:25 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
