R56 09 mini s motor replacement
Old Oct 3, 2013 | 04:06 AM
greenmonster1918's Avatar
greenmonster1918
I just picked up an 09 cooper s needs a motor. Should I buy a used one or remanufactured? Ballpark pricing any recommendations on Boston area independent Techs that could handle the job. Thank You
Old Oct 3, 2013 | 06:06 AM
richardsperry's Avatar
richardsperry
First, hi and welcome...
Second, why does it need a engine?
Third, I've seen used engines on Fleebay for about $2500, Or you can check out Car-part.com. A reman from MINI will be about $6500...
Old Oct 3, 2013 | 06:18 AM
greenmonster1918
Timing chain broke, so I am trying to decide whether to fix it, sell it as is, or put in a used motor, or re manufactured factory unit.
Old Oct 3, 2013 | 08:00 AM
countryboyshane's Avatar
countryboyshane
If the valves collided with the pistons you're better off with a used or re-man engine.
TJ @ Detroit Tuned might be able to get you a better price for a reman engine than $6500.
Old Oct 3, 2013 | 08:12 AM
borderwave2's Avatar
borderwave2
I say rebuild it with stronger pars. Shouldn't cost more than a regular used engine.
Old Oct 3, 2013 | 08:16 AM
greenmonster1918
My price out the door installed 6400.00
N-14 engine, clutch kit, turbo heat shield, new turbo oil lines, Fluids, gaskets, nuts bolts ect.
Old Oct 3, 2013 | 12:52 PM
gregdconsulting's Avatar
gregdconsulting
Boston area
Talk to the mechanics at http://www.greasysgarage.com/. They are well spoken of by the people on massmotoringclub.com (Greasy's does sponsor the forum). You would have to get the car to Worcester. I would be talking to them if I were in the same situation.
Old Oct 3, 2013 | 01:11 PM
greenmonster1918
Thank You I just touched base with Tom and he said ballpark 5000/7000 for used. Thank You for the help.
John
Cereall
Sep 5, 2019 06:05 PM
Dec 23, 2015 10:36 AM
tr3y003
Oct 22, 2015 10:48 AM
kwijmbo
Aug 5, 2015 09:00 PM
