Suspension Rear subframe misaligned?
Old Oct 1, 2013 | 06:47 PM
Mindspin311's Avatar
Mindspin311
Is this possible? I put wider wheels and tires on my car last week, 16x7.5, 205/55/16, and during the alignment we noticed that the drivers side wheel protruded further out from the fender than the passenger side.
Passenger side:
Drivers side:
A quick look at the subframe, and it appears to be centered. Camber and toe came out perfectly, -1.5deg on both sides, toe was even side to side as well.
Pretty stumped.
Old Oct 2, 2013 | 03:17 AM
robbo mcs's Avatar
robbo mcs
More likely that the panels and or wheel arch trim are not straight rather than the subframe.
The other obvious thing is spacers. You haven't left a spacer on the hub or the wheel by mistake?
Old Oct 2, 2013 | 04:24 AM
v10climber's Avatar
v10climber
Were the wheels/tires new? Are they all the same offset?
Old Oct 2, 2013 | 05:09 AM
Mindspin311
I purchased the wheels used, had them refinished and painted.
I never thought that one of the 4 could be a different offset. I guess Ill go back and check. They should be +43.
I have the fender a slight pull this morning, no way that it could be manipulated easily to clear.
Old Oct 2, 2013 | 07:57 AM
brightside's Avatar
brightside
My car is like this also. Could it be the subframe causing the issue? I've had mine off from a rear sway bar upgrade. Maybe it was shifted to one side on the bolt hole clearance.
Old Oct 2, 2013 | 08:17 AM
HorizonBLueN18's Avatar
HorizonBLueN18
my old gti had this issue. rear driver side tire stuck out 1/16 of an inch and rear passenger side was in 1/16 of an inch. I found it extremely frustrating that my tires were 1/8 of an inch off. this might sound trivial but when you are going for a flush look it was defintely noticeable.
Old Oct 2, 2013 | 09:12 AM
mbwicz's Avatar
mbwicz
It seems odd to have the alignment of the rear cradle out that much. I would just put a spacer (5mm?) on one wheel to make them look even.
The expensive option is to get 2 sets of adjustable RCA's and use that to adjust the track width. You can use the toe adjustment at the frame to bring the wheel in or out, then balance the alignment with the RCA's.
Have fun,
Mike
Old Oct 2, 2013 | 11:39 AM
Mindspin311
Is there a mystery adjustment in the upper LCA that no one knows about?
Old Oct 2, 2013 | 11:40 AM
Mindspin311
Have fun,
Mike
I thought about that. If it really comes to it. That one wheel rubs on really hard bumps.
Old Oct 2, 2013 | 12:24 PM
mbwicz's Avatar
mbwicz
Just to be sure, swap wheels left to right to confirm that the issue is not related to the wheels. I would expect that the wheels are accurate, but it would be good to eliminate this possibility.
No adjustment in either factory control arm (upper or lower). I've never played with the toe adjustment, but you can probably look at them to confirm that there is adjustment to bring the offending wheel inboard.
There is also the possibility of loosening the subframe bolts and trying to move the subframe the way that you want. Just trying to think of all the options for you....
Good luck,
Mike
Old Oct 2, 2013 | 06:23 PM
Mindspin311
I dont think the wheels are a different offset. Havent officially taken the wheel off and looked at the stamp. But, looking at my wheel studs, there are the same amount of threads showing and the "dish" of each wheel seems equal.
Just non-scientific observation.
Old Oct 3, 2013 | 02:45 AM
mbwicz's Avatar
mbwicz
I would agree that there is little chance of the wheels being different or wrong from one to another. Just trying to think of all the potential causes.
Good luck,
Mike
Old Oct 3, 2013 | 04:43 AM
Herleman's Avatar
Herleman
More likely that the plastic has warped a bit making it appear that one is protruding more than the other. The only way you'll know for sure is to determine the exact center of the car and measure the track based on the relationship to the center line. if the car is properly aligned and is tracking correctly, I'd look at the body first before I'd try offsetting anything.
emulajavi
Dec 24, 2018 09:15 AM
maestro39
Oct 27, 2015 02:38 PM
minimofo
Sep 9, 2015 10:29 AM
minipopkart
Aug 13, 2015 05:22 AM
