R56 No switch for driving lights?
Old Sep 23, 2013 | 04:45 PM
BrandonM3's Avatar
BrandonM3
Hi there,
New to MINI but have been a BMW owner since my first car. On all BMWs with driving lights (aka "fog" lights), there's a switch to turn them on or off. I don't see that with our new MINI. They just turn on whenever the headlights are on. Is that normal or am I doorknob?
Brandon
Old Sep 23, 2013 | 04:53 PM
danjreed's Avatar
danjreed
There should be a set of switches on the lower row of the console.
If your car is equipped with factory fogs the switch is down there, and icon is on the center speedo.
If you want to see if your car was equipped with them from the factory - punch the last 7 of the VIN into here:
http://www.bmwarchive.org/vin/bmw-vin-decoder.html
It will give you the factory build sheet.
Old Sep 23, 2013 | 04:54 PM
MINILLA's Avatar
MINILLA
Originally Posted by BrandonM3
Hi there,
Brandon
Pretty sure that if there is no switch then you don't have fog lamps...
Old Sep 23, 2013 | 05:56 PM
eaglebeagle's Avatar
eaglebeagle
the lower lamps on minis are top 1/2 parking light, bottom 1/2 optional fogs. If the bottom half doesnt have a lamp in it you've just got parking lamps. I made the same mistake(if thats the case for you)
Old Sep 25, 2013 | 12:41 PM
BrandonM3's Avatar
BrandonM3
Ohhhhhh, OK that makes sense. I can see that there is a separation there. So there is not an option to turn the parking lamps on or off I'm gathering.
Old Sep 25, 2013 | 12:55 PM
InjectedGT's Avatar
InjectedGT
No. headlights on=parking lamps on. No manual control at all.
Old Sep 25, 2013 | 12:58 PM
Yep, there are two different housings. MINI with parking ( position lights ) and MINI with fog light & Position light . If you have the toggle switch in the toggle bank then you have the position light & fog light combo. Turn your parking lights (first click on the stalk) on and the position light , lights up as well as the side marker lights, etc.
Front Fog Light With Position Light You can see the two bulbs. 1/2 upper , 1/2 lower. 63172751295
http://www.ecstuning.com/Search/SiteSearch/63172751295/
Parking Light 63172751293
http://www.ecstuning.com/Search/SiteSearch/63172751293/
We now have LEDs for the positions light portion on both light type ( replaces the little wedge bulb on left and right side ) and no bulb out error to worry about. We should be getting these back in stock soon.
Ziza Front Position Light LEDs
http://www.ecstuning.com/Search/SiteSearch/003654ZIZ01KT/
Position Only Housing lights example. ( you can see no fog light )
Position light & fog light combo housing ( fog is lower section )
Old Sep 25, 2013 | 01:27 PM
ZippyNH's Avatar
ZippyNH
Also of note that to the op...the lenses/reflectors on both lights are different...
Fog lights have a broad beam...short throw...
Driving lights have a narrow, long throw beam, like a high beam...
Wohnson89
Jun 10, 2020 04:53 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
JHolland
Aug 13, 2015 10:47 PM
