R56 Exhaust question
Old Sep 21, 2013 | 05:09 AM
RobMuntean's Avatar
RobMuntean
Exhaust question
So I'm buying the FJCW muffler sometime this week, I gave up searching for someone cause I'm not driving to different states unless it's Indiana or Ohio lol.
My question is, should I stick with the 2.5" straight piping which will be sleeved to fit the FJCW muffler or go back to the stock piping 2.25"? Does it even matter at this point? Thanks.
Old Sep 21, 2013 | 08:03 AM
countryboyshane's Avatar
countryboyshane
Might as well stick with 2.5" like you have. You're already vested in the 2.5" piping so might as well stick with it instead of going back to stock.
Old Sep 21, 2013 | 08:43 AM
RobMuntean's Avatar
RobMuntean
Cool thanks Shane!
Old Sep 21, 2013 | 06:40 PM
mbwicz's Avatar
mbwicz
Good luck with fitting, I agree that you should stick with the straight pipe that you have and figure out how to make it work. You will likely be able to insert the 55mm pipe into the 2.5 and weld it, or you could take a section of the old pipe and weld it into the 2.5" pipe. Then you can use a band clamp to connect the front and rear sections, if you don't want them hard welded.
http://www.ecstuning.com/Mini-2008-C...amp/ES1875593/
I was unable to meet up with the seller on my trip, so I'm still looking for one.
Enjoy your car and your vacation.
Have fun,
Mike
Old Sep 23, 2013 | 05:06 AM
DOtheDEW's Avatar
DOtheDEW
just a heads up, i just purchased the fjcw muffler from ECS last week, i spoke with Rob and he was very helpful, i plan on doing a straight piping from the 2nd cat back to the fjcw muffler
Old Sep 23, 2013 | 02:44 PM
mbwicz's Avatar
mbwicz
DotheDew,
I would do some searching, I bet that most guys eliminated the resonator and/or second cat when installing their MCS. JMO, but the 2nd cat is probably pretty restrictive, so I would think that any sound improvement would be minimal with just a muffler change. Like I said, I don't have any experience with this, just a thought.
If you are having a length of pipe cut and welded, it is just as easy to make it a little longer and eliminate one or both of the other factory parts.
Mike
Old Sep 23, 2013 | 05:01 PM
RobMuntean's Avatar
RobMuntean
Originally Posted by mbwicz
Good luck with fitting, I agree that you should stick with the straight pipe that you have and figure out how to make it work. You will likely be able to insert the 55mm pipe into the 2.5 and weld it, or you could take a section of the old pipe and weld it into the 2.5" pipe. Then you can use a band clamp to connect the front and rear sections, if you don't want them hard welded. http://www.ecstuning.com/Mini-2008-C...amp/ES1875593/ I was unable to meet up with the seller on my trip, so I'm still looking for one. Enjoy your car and your vacation. Have fun, Mike
Thanks Mike. Sewell had it for a good price and I couldn't pass it up. Plus since I can weld it to the 2.5" piping it'll be fantastic with my resonator and 2nd cat off already. I'm going to try and break it in quickly lol.
WestfaliaR
Aug 19, 2015 08:01 AM
elightbo
Aug 17, 2015 01:50 PM
Aug 12, 2015 01:24 PM
massmini03
Aug 12, 2015 11:19 AM
papawhiskey
Aug 10, 2015 09:31 PM
