R56 Which Pierburg Pump Is This????
This part is mounted on what I believe is the transmission in the front of the car. It is a Pierburg pump, but I cannot figure out which pump it is. The part numbers on the unit do not match up with MINI part numbers. Any ideas?
Its the auxiliary water pump , this is the part number with most updated part. It runs a little after you shut the MINI off and makes a little whirling noise heard near the front driver side.
#1 in the diagram.
Additional Water Pump ( auxiliary ) Part # 11537630368
http://www.ecstuning.com/Search/SiteSearch/11537630368/
#1 in the diagram.
vulkandino
Oct 31, 2015 08:29 PM
Oct 1, 2015 12:13 PM
