R56 JCW motor going into my MCS, started work today
Old Sep 10, 2013 | 12:08 PM
dodgyparker's Avatar
dodgyparker
Any tips for a first time engine swap? Planning to get the thing going using all OEM stuff, then start doing some modding from there.
I know I'll need to swap out the MAP sensor from the MCS to the new motor to work.
All I've done so far is dump the fluids from the old engine. The old one is being swapped because it is leaking / burning oil and has a lot of miles (160k). Got a great deal on the minty fresh JCW.
Attached Thumbnails JCW motor going into my MCS, started work today-photo-1.jpg   JCW motor going into my MCS, started work today-photo-2.jpg
Old Sep 10, 2013 | 12:27 PM
Agbullet25's Avatar
Agbullet25
I personally haven't done any engine swaps, but have read and followed many across many platforms. The biggest piece of advice I can give you is to label everything! Label where all the wiring looms go, where the vacuum lines go, where any electrical connections go, etc. This will save some headache down the road when trying to make sure everything is going to work properly.
Old Sep 10, 2013 | 02:17 PM
v10climber's Avatar
v10climber
Provided it's an N14 to an N14 there shouldn't be anything different. The only real differences were internal to the engine (pistons). The rest of the stuff should be the same. I'm not sure if you'll need the ECU or not. Are you swapping just the motor or accessories and everything? You know the JCW turbo is different right?
Old Sep 10, 2013 | 03:02 PM
countryboyshane's Avatar
countryboyshane
Done an engine on my dad's Neon one time. Biggest advice is to just look at the job task by little task. It's when you look at the big picture that it can be daunting.
Take lots of pictures as you remove things you are unsure of.
Store all fasteners in ziplock bags with clear understandable labels. Tape fastener bags to part it came from.
Biggest thing is to take your time. If you rush, you WILL screw up.
My biggest question is if the base calibration is different between MCS and JCW. I am more inclined to think so based on the JCW having a lower compression ratio and different turbo.
Old Sep 10, 2013 | 07:55 PM
dodgyparker
Yes, I know that the ECU settings are definitely different. I am going to put my MCS turbo on for now and will be putting a JCW or Gpop on and tuning after I make sure everything else is working ok. I know that the MAP sensor does not fit the wire harness, so I will need to swap that out as well.
Old Sep 11, 2013 | 07:58 AM
countryboyshane
I'm not saying it won't run out of the box, but I would talk with an expert about what the biggest concern is. Maybe someone at the dealer could help.
Old Sep 12, 2013 | 12:09 PM
dodgyparker
I've been working about 2 hours at a time and just got her nose off!
I am thinking of going ahead and doing some mods while in there.... not sure I want to have to take the front clip off again!
As soon as I can get the turbo off, I think I'll send it to Gpop, and finish the buildup when I get it back. Any other suggestions while I'm in there?
Old Sep 12, 2013 | 12:13 PM
dodgyparker
indecent exposure
Attached Thumbnails JCW motor going into my MCS, started work today-photo-3.jpg
Old Sep 12, 2013 | 01:33 PM
cjm's Avatar
cjm
dodgyparker, please keep updating and taking pics.
What you're doing is really unique and IMO one of the most interesting posts I've seen in ages.
Loadsa luck
Old Sep 12, 2013 | 08:48 PM
dodgyparker
OK, update. Forgot to take pics, will do so tomorrow.
Old engine and transmission are OUT! Turbo, Alternator, and AC compressor are OFF!
All nuts and bolts accounted for. Hoping to have new motor put in before lunch tomorrow.
On consideration, I think I may reinstall everything and see what happens with a remap before I do anything with the turbo. Any suggestions on who to call in order to program my MCS to think it's a JCW?
Old Sep 12, 2013 | 08:49 PM
dodgyparker
Also, any idea of what to ask for a smooth and strong running 160k motor with an oil leak?
Old Sep 14, 2013 | 09:51 AM
jcarl126's Avatar
jcarl126
any hardware you pull off the engine (rad. bolts, engine mount hardware, etc) put in separate plastic ziplock bags and label with a sharpie. get a liquid chalk pen to mark hoses, ac lines, all that good stuff. get a bunch of heavy duty black zipties as those will come in handy on the freshly installed engine AND help keep lines held out of the when when removing/installing. good luck man! let us know then crank the boost!
Old Sep 15, 2013 | 08:02 PM
borderwave2's Avatar
borderwave2
I think you would require a the stock DME flash from a JCW car for it to run. The timing and fuel maps are all different from a regular cooper s. I imagine it would run, but your boost would never reach what it should with the stock tune.
Old Sep 15, 2013 | 11:59 PM
Thruxton's Avatar
Thruxton
Your local dealer can tune it up for you. Should be around a $125 charge, but without the JCW turbo, i think your computer is going to throw some boost pressure plausability faults. That is - it thinks its not generating enough boost (because its not) for the JCW tune. Good luck! BTW - I'm a SA at a MINI dealership, let me know if i can be of any assitance on the reassembly.
Old Sep 16, 2013 | 12:06 AM
cjm's Avatar
cjm
...this is why I'm so enthused to have access (thanks dodgyparker) to all the areas he "boldly goes". Also, how much interest, goodwill and support might be expected from the local dealer etc...
Old Sep 16, 2013 | 06:30 AM
borderwave2
Originally Posted by Thruxton
Your local dealer can tune it up for you. Should be around a $125 charge, but without the JCW turbo, i think your computer is going to throw some boost pressure plausability faults. That is - it thinks its not generating enough boost (because its not) for the JCW tune. Good luck! BTW - I'm a SA at a MINI dealership, let me know if i can be of any assistance on the reassembly.
Hypothetically speaking, is it possible for one of the service guys to flash my car with a JCW or JCW Stage 1 tune "under the table." I am cool with several of the service guys at my dealer who could do this for me if its possible?
Old Sep 16, 2013 | 07:51 AM
yetti96's Avatar
yetti96
I don't think so. The JCW tunes are serialized and vin locked. They would need to have the serial number of a dealer installed kit or perhaps the original one form the car you got the engine from.
Old Sep 16, 2013 | 10:12 AM
axleR56's Avatar
axleR56
I thought only the tune from the JCW Tuning Kit was serialized and vin locked?
I could be wrong.
Old Sep 16, 2013 | 10:34 AM
802R56's Avatar
802R56
This is a very cool thread! I look forward to seeing the results! I am a technician at a local MINI dealer also let me know if you need any help!
Old Sep 17, 2013 | 07:28 AM
borderwave2
That's what I thought. Thruxton said a dealer would slap a factory JCW tune on this guy's ecu for $125. I'd do this in a heartbeat if it's true...
Old Sep 17, 2013 | 07:38 AM
yetti96's Avatar
yetti96
A factory tune is different than the JCW upgrade as it had to be serialized. The dealer can flash cars with newer software and have possible issues and need to reload a tune in theory. They should be able to get a factory tune and run it on a factory car/motor. I doubt us MCS guys can just slap a JCW tune on a S without changing some stuff and really getting any benefit.
Old Sep 17, 2013 | 08:45 AM
dodgyparker
Sorry for the tardy update, my Dad's back in hospital (ongoing health issues) and that's occupied most of my mental space the past few days, but I did get back to work yesterday.
Anyway, here's where the swap is now:
New engine is in the car, old turbo and new (JCW) manifold have been sent off to JM Turbo Coopers in AZ for rebuild and manifold porting. Anyone else have a %^&*# of a time getting the nuts off of the manifold-to-turbo studs? I had to use a chisel to break them off!
Looking at different options as far as tuning and which turbo level to build to (here's the menu: http://www.jmturbocoopers.com/All-Mi...er-Turbos.html), as well as doing a different downpipe and water/meth injection while I'm in there.
Any suggestions?
Attached Thumbnails JCW motor going into my MCS, started work today-image_1.jpeg   JCW motor going into my MCS, started work today-image_4.jpeg   JCW motor going into my MCS, started work today-image_5.jpeg
Old Sep 17, 2013 | 10:16 AM
Ian Landesman's Avatar
Ian Landesman
Subscribed!
Super cool! Keep us update with your build notes.
Upgrade your FMIC, charged air pipes, and recirc (blow off) valve. Definitely put on the JCW air intake. =D
Old Sep 18, 2013 | 08:42 PM
Thruxton's Avatar
Thruxton
No it has to be qualified. If he has the motor and it has a valid JCW engine code on it then you might have a shot at it accepting the programming. Did not mean to mix words there
Old Sep 19, 2013 | 03:58 AM
richardsperry's Avatar
richardsperry
Call Jan at Revolution Motor Works. or buy an Accessport.
