Tire pressure for the stock 17 inch run flats
Old May 11, 2004 | 01:44 PM
Timmons's Avatar
Timmons
What is the best pressure at which to keep these tires? They say max of 51psi. They came delivered with 33 psi.
Old May 11, 2004 | 02:44 PM
Alex@tirerack's Avatar
Alex@tirerack
33 psi is on target!
Alex
Old May 11, 2004 | 02:47 PM
apexer's Avatar
apexer
Most I've talked with and posts I've seen here and elsewhere say 33/34 lbs. Thats what I have been using for 6K miles and ware looks even.
Old May 11, 2004 | 07:48 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
51 psi max is the maximum pressure for that tire. It doesn't mean you should run that pressure.
Each car has a recommended pressure and yours is on the metal plate inside the driver's door jam. Look at the size wheels and tires you have and match how many people are in the car.
33 psi is fine for 2 people and 37 psi is fine for 4 people for the MCS with 17" wheels. Read your psi off the plate if you have the MC. You can choose something in between if you want or just run the higher number of the two in case you need to take some passengers for a ride.
Old May 11, 2004 | 10:25 PM
kenchan's Avatar
kenchan
DSST SP9000's, I use 35psi all around.
Old May 24, 2004 | 08:25 AM
Timmons's Avatar
Timmons
Thanks!
Old Sep 7, 2004 | 08:36 AM
Rick-Anderson's Avatar
Rick-Anderson
I recently had my car serviced at Crevier and was surprised this morning when I checked my tire pressure and found 27psi all around. I adjusted it to 33 as per the sticker on my door. I have Pirelli 17" runflats.
Old Sep 7, 2004 | 10:29 AM
kenchan's Avatar
kenchan
A lot of dealers forget to pump the tires...including mine!
When i bought my car, it only had about 25psi.
Old Sep 7, 2004 | 12:55 PM
Rick-Anderson
It is amazing how much different the car feels now! I still want to get rid of the runflats and rims, though. I am exploring wheel and tire options. It seems that you can buy a decent set of tires and rims for the cost of four new runflats - And save a hundred pounds in the process!
Old Sep 9, 2004 | 05:56 PM
JoeDentist's Avatar
JoeDentist
Shouldn't a car with a 60/40 weight distribution like the Mini use a higher inflation pressure in the front than the back? Is it 33 psi all round?
Powershift
Aug 16, 2015 05:14 PM
sabjcw
Aug 14, 2015 07:40 AM
Terry Gallentine
Aug 11, 2015 03:31 PM
nomar116
Aug 9, 2015 09:42 AM
