broken exhaust hanger r53
Old Aug 17, 2013 | 09:13 AM
Scanner's Avatar
Scanner
2005 MCSa
mid-chassis, just under the support plate...both ends broken/rusted at pipe connection...is there a replacement bracket for this or is a new exhaust needed?...was making clanking noises on some bumps and that prompted the undercarriage investigation...I zip-tied them away from the pipe for now...any suggestions appreciated ---John
Old Aug 17, 2013 | 02:44 PM
mrbean's Avatar
mrbean
For a well equipped shop, it should be easy to fabricate and weld a new bracket. New exhaust systems are pretty pricey and this seems like a simple fix for someone with the right tools and knowhow.
Old Aug 17, 2013 | 03:57 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
It's not so much a bracket as it is two outreaching pices of 4 inch round stock welded to the pipe.
But if it's just the quirky looking rubber mounts that failed you can replace those.
Old Aug 17, 2013 | 04:16 PM
Scanner's Avatar
Scanner
the round stock broke off at the pipe on both sides...rusted away
Old Aug 20, 2013 | 07:34 AM
JeffM's Avatar
JeffM
A decent exhaust shop should be able to bend a piece of rod to wrap below the pipe and stick out both sides into the hanger rubber pieces, and tack it to the pipe in a couple of spots. Maybe grind down the stubs of the originals while they're at it.
Old Aug 20, 2013 | 08:32 AM
Scanner's Avatar
Scanner
that's probably my best bet...that hanger doesnt seem to provide much support anyway
thanks for all your help guys !
Old Aug 20, 2013 | 11:38 AM
Without replacing the stock exhaust the mounts in the middle above #8 in the diagram are welded in place.
I was think you might be able to tack back if its not rusted that bad or fab up a new rod using some of the hardware from the rear. Since they have a similar design. #17 and 18.
Supporting Bracket - Left
http://www.ecstuning.com/Search/SiteSearch/18201493798/ES39895/
and
Supporting Bracket - Right
http://www.ecstuning.com/Search/SiteSearch/18201493797/
Clean the coating , bend them straight, cut and tack them on.
That might work.
Teh
Aug 22, 2022 04:37 AM
Jan 4, 2019 12:51 PM
replacement
Aug 19, 2015 08:46 AM
Aug 12, 2015 01:24 PM
Aug 11, 2015 11:58 AM
