R56 Rear brake caliper piston retracting tool
Old Aug 11, 2013 | 05:33 PM
papatom360's Avatar
papatom360
Hello,
I am getting ready to change the brakes on my 2010 MCS soon and I saw this tool in the "brake parts" section of this website. I was wondering if any of you have changed your own brakes before and needed this tool to complete your installation? Would I just be able to use a "C-Clamp" to push the piston back in? I just want to make sure I have everything I need when I go to change them in a couple weeks.
Thanks!
Old Aug 11, 2013 | 05:37 PM
JAB 67's Avatar
JAB 67
Assuming Gen2 rear brakes are like Gen1 rears, you need to both rotate and compress the pistons; that is what the 'special' tool does.
Old Aug 11, 2013 | 05:40 PM
Braminator's Avatar
Braminator
Most auto parts store sell this tool and some have a universal square block that attaches to your ratchet for under $10.00 It is not so much about pushing it in as it turns in, so never use a c clamp or you will ruin them.
v10climber's Avatar
v10climber
Originally Posted by papatom360
Hello,
Thanks!
No you can't just compress the rear piston with a c-clamp. You can use it on the front but the rears require the tool. You'll damage the caliper that way if you succeed at all. The caliper has to twist while its being pressed in. Some people have managed without the tool but its really rough without it. Harbor freight sells the tool for ~$35 or you can use it for free if you "rent" it from a local auto parts store like advance or autozone. They typically have tool rental programs
Old Aug 11, 2013 | 05:41 PM
Braminator's Avatar
Braminator
Looks like this
Old Aug 11, 2013 | 05:57 PM
papatom360's Avatar
papatom360
Thanks everyone! I will definitely use the "special tool" whether I have to buy it or rent it.
Old Aug 11, 2013 | 06:36 PM
Azminispeedin's Avatar
Azminispeedin
Omg, just use a C-clamp...done and done
Old Aug 11, 2013 | 06:50 PM
Braminator's Avatar
Braminator
You CAN'T! It does not push in, it screws in.
Old Aug 11, 2013 | 07:30 PM
Turbo R53's Avatar
Turbo R53
Haha...wow...do you have a clue about how anything works?
A c-clamp will work as I have used it many times on my rear calipers...as you tighten the clamp(righty-tighty) the caliper piston will retract as it needs to go in the same direction you're turning the clamp.
The only issue is if the clamp has a "floating" head on it, you will need to wrap it to the lead screw with electrical tape so they both turn together.
Old Aug 11, 2013 | 07:32 PM
Braminator's Avatar
Braminator
Old Aug 11, 2013 | 07:33 PM
Braminator's Avatar
Braminator
I guess using the right tools for the right job is not your cup of tea Turbo.
Old Aug 11, 2013 | 08:48 PM
Turbo R53's Avatar
Turbo R53
I actually have the tool, different than the one you posted...the one that Bavarian Autosport sells...
I'm not trying to give you a hard time in every thread you post in, but if you give incorrect info, then I have to chime in and give the correct info.
It's fine if you don't work on your own car and don't know what works and what doesn't, you're not the only one out there...just be conscious about your posting.
What if some newbie came in this thread with the same question and read that the special caliper piston tool is all he could use, while he actually had a C-clamp that would work in his tool box. His car was his only ride and he had to go to work or school the next day...or give someone a ride somewhere, etc...that's all I'm saying.
Make sure you know 100% what you're talking about.
Old Aug 11, 2013 | 08:50 PM
Braminator's Avatar
Braminator
[QUOTE=Turbo R53;3790345]I actually have the tool, different than the one you posted...the one that Bavarian Autosport sells...
I'm not trying to give you a hard time in every thread you post in, but if you give incorrect info, then I have to chime in and give the correct info.[/QUOTE
get a life. I gave the right info and you just proved my point. Thx.
Old Aug 11, 2013 | 08:52 PM
danjreed's Avatar
danjreed
You will ruin the caliper... Rear internal parking brake units must be spun in as they are retracted..
Front calipers are far less complex.
Old Aug 11, 2013 | 08:56 PM
danjreed's Avatar
danjreed
Dude... Guy... Easy..
Electrical tape? I've had rear calipers that broke the proper tool.. And you think electrical tape is going to work to lock the head of the clamp down... Let alone not slip on the caliper's piston?
Just get the free rental from Autozone..
Old Aug 11, 2013 | 09:05 PM
Turbo R53's Avatar
Turbo R53
I've done it, it works...you guys need to work on your cars more.
Old Aug 11, 2013 | 09:08 PM
Braminator's Avatar
Braminator
Dan I guess you and I don't work on enough cars. You might want to school him in what you do.
Old Aug 11, 2013 | 09:10 PM
Turbo R53's Avatar
Turbo R53
You specifically stated..."You CAN'T! It does not push in, it screws in."...referring to using a C-clamp. When in fact a C-clamp will work if you don't have the tool.
I have a life, and apparently a much better one than you hahaha
Braminator's Avatar
Braminator
Old Aug 11, 2013 | 09:17 PM
Turbo R53's Avatar
Turbo R53
We work on cars using the right tools. We don't half *** things to make it work. I hope you don't work on cars or I would be real scared. Im also glad I don't live in RI or I would definitely not want to drive knowing you or anything you worked on is on the road.
I doubt you work on anything except a cafe latte while getting your nails done.
Nothing I do is ever half ***, but I would be scared of anything you turned a wrench on.
Old Aug 11, 2013 | 09:19 PM
Braminator's Avatar
Braminator
Its actually a Frappe.
Old Aug 11, 2013 | 09:22 PM
Braminator's Avatar
Braminator
BTW. I have had two cars featured in National Magazines. Sport Compact Car January 1996 a 1995 Acura Integra GSR and Vette magazine 1995 a 1993 Vette Convertible. Both cars built by me.
Old Aug 11, 2013 | 09:25 PM
Braminator's Avatar
Braminator
Sorry to the OP for this nonsense.
Old Aug 11, 2013 | 09:48 PM
InjectedGT's Avatar
InjectedGT
I've always had an entire piston compressing kit in my garage, so it's hard to say how well all the half assed and rigged up ways work on the Mini lol. I've done the little cube before(and it was still not that great), and I've done the slow and tedious way with pliers. If you plan to do brakes on your car or others' cars in any kind of quantity, get an entire kit. It's like $40 and is the quickest, easiest, and best way of doing it. I can try and find a link to a good one for you if you'd like.
Old Aug 11, 2013 | 09:55 PM
InjectedGT's Avatar
InjectedGT
http://www.harborfreight.com/18-piec...kit-69053.html
that right there is a staple in my garage. Whether you have screw in pistons, normal pistons, doesn't matter. I use it every time. Too easy/convenient/simple not to.
