R60 MINI Connected engine hp
after poking around a bit i couldn't get a straight answer...is the engine hp/torque reading of the MINI Connected app accurate ?
are the readings consistent ? ...any of u guys who had an ECU tune or whatever mod is getting higher values ?
i'm looking to retrofit my 2012 CMS ALL4 with said app and was most interested about this aspect
thanks a bunch
thanks a bunch
What sport gauges did you have? I have the connected/NAV package in my Paceman and will be getting an iPhone this fall when the (5S,6?) comes out. The manual mentions sport gauges, but doesn't clearly describe them.
David
David
I had no problem with any of it on my iphone 5 until the app update. No idea if it's permanent or not.
I'm taking a stab in the dark here, but I assume the hp shown is the hp generated (at the moment) to keep you running at the rpm & speed you are driving. I've seen mine as low at 19hp to keep me moving down the road.
Dec 23, 2015 10:36 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
tippin
Aug 5, 2015 08:43 AM
