R60 MINI Connected engine hp
Old Jul 30, 2013 | 08:40 AM
Bigblack's Avatar
Bigblack
after poking around a bit i couldn't get a straight answer...is the engine hp/torque reading of the MINI Connected app accurate ?
are the readings consistent ? ...any of u guys who had an ECU tune or whatever mod is getting higher values ?
i'm looking to retrofit my 2012 CMS ALL4 with said app and was most interested about this aspect
thanks a bunch
Old Jul 30, 2013 | 08:51 AM
ignitionmodule's Avatar
ignitionmodule
I don't know if it's accurate, but I have seen mine above 208hp, which is the advertised peak.
Since the app update though, I've lost my sport gauges.
Old Jul 30, 2013 | 08:56 AM
Bigblack's Avatar
Bigblack
what update might that be ? ..does it deal with the hp/torque reading ?
Old Jul 30, 2013 | 09:44 AM
HamsterDR's Avatar
HamsterDR
What sport gauges did you have? I have the connected/NAV package in my Paceman and will be getting an iPhone this fall when the (5S,6?) comes out. The manual mentions sport gauges, but doesn't clearly describe them.
David
Old Jul 30, 2013 | 10:07 AM
ignitionmodule
No idea, it was just an app store update. Worked for a little while and then poof, no more sport gauges.
Old Jul 30, 2013 | 10:10 AM
ignitionmodule
David
There are a couple of additional gauge faces in the driving excitement app. One is relative g forces, basically shows you which way you are leaning, and the other is a set of hp/torque gauges.
I had no problem with any of it on my iphone 5 until the app update. No idea if it's permanent or not.
Old Jul 30, 2013 | 04:58 PM
champ198's Avatar
champ198
I'm taking a stab in the dark here, but I assume the hp shown is the hp generated (at the moment) to keep you running at the rpm & speed you are driving. I've seen mine as low at 19hp to keep me moving down the road.
Dec 23, 2015 10:36 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
noreen99
Aug 8, 2015 08:21 AM
tippin
Aug 5, 2015 08:43 AM
