Tach issue
Old Jul 24, 2013 | 06:00 AM
ou812_tugger's Avatar
ou812_tugger
Tach issue
Does anyone know why my tach would be reading about 1,000 RPM higher then actual RPM? When I turn my 05 cooper S off the tach stops at 1,000 RPM (not going to zero) and now it reads the RPM about 1,000 higher than normal.
Old Jul 24, 2013 | 09:15 AM
rkw's Avatar
rkw
I don't know what might have caused the misalignment, but you can open the tach and reposition the needle. Look at the instructions here: https://www.northamericanmotoring.co...with-pics.html
Old Jul 25, 2013 | 05:01 AM
ou812_tugger
Do you think resetting the ECU would possibly correct the problem?
Old Jul 25, 2013 | 08:45 AM
rkw's Avatar
rkw
It wouldn't hurt to try it, but realistically I think you will have to physically reposition the needle.
Old Jul 26, 2013 | 10:09 AM
ou812_tugger
*UPDATE*
Resetting the ECU did it. I am not sure what the cause was but after finding the thread on NMA about resetting the ECU I figured that I would give that a try before tearing into the tach or spending $150 dollars for the dealership to look at it. Good to go!!!
rtk90
Aug 29, 2019 09:08 AM
Mini Koopa
R55 :: Clubman Talk (2008+)
Sep 8, 2015 02:58 PM
tylewis
Sep 6, 2015 01:07 PM
jesterofatlas
Aug 31, 2015 07:58 AM
finn
Aug 21, 2015 07:59 AM
