ABS delete
Old Jul 22, 2013 | 08:19 PM
esfreerider's Avatar
esfreerider
ABS delete
I would like to disable my ABS. I undid the sensor under the windshield on the passenger side for a day but that left me with various warning lights and no speedo so that killed that idea.
Is there a easy fuse to just unplug? or better yet a way to hook it up to a toggle switch and put it in the toggle panel?
Old Jul 22, 2013 | 08:48 PM
CarlosDMotor's Avatar
CarlosDMotor
I don't see a fuse for ABS. I think that it is integrated with DSC. In the bentley manual, it says there is a control module in the engine bay, I think its the sliver thing where the brake vacuum booster tube goes to. Under the ECU. If you want to disable the DSC, there are 4 fuses that are labeled as DSC
Old Jul 22, 2013 | 11:36 PM
martinb's Avatar
martinb
Why disable it?
Old Jul 23, 2013 | 05:08 AM
v10climber's Avatar
v10climber
You're probably going to get check engine lights no matter what you do. The car checks the ABS system during start up and any faults will trigger a CEL. Most of the rally-x guys (not in minis but still applicable) just pull the fuses.
Old Jul 26, 2013 | 08:07 PM
esfreerider
Originally Posted by sctony
I don't know why you want to disable the ABS system usually car checks every system on start up like ABS system and other fuse and sensors.
This is my first sports car with ABS and I feel like it gets in the way. I had it disabled and could stop faster (on dry black top) and during hard left foot brake turn ins the ABS is way to sensitive. And in those left foot brake turn ins it won't give the inside front wheel enough brake pressure witch leads to understeer when in the same turn same conditions I can get the rear end to rotate.
Old Jul 27, 2013 | 04:12 AM
MINILLA's Avatar
MINILLA
Without the ABS you're going to get a lot of the car to rotate!!!!!
Old Jul 27, 2013 | 02:48 PM
esfreerider
Yes. I have had it disabled and have found that under the conditions I described that I can get a small amount of oversteer. Hard left foot braking can cause overseer when done right but with ABS it becomes much harder as you get uneven braking up front which in turn acts like a turning brake pulling the in the opposite direction of the intended turn with a net result of understeer.
Old Jul 27, 2013 | 03:23 PM
esfreerider
Without ABS I'm not locking up the brakes btw
Old Jul 27, 2013 | 03:47 PM
rkw's Avatar
rkw
ABS can probably be disabled through NCS Expert programming. Sensitivity might even be adjustable in the software. I doubt that you can simply disable it by disconnecting some connector, because the same sensors are used for multiple functions.
Old Jul 27, 2013 | 04:00 PM
esfreerider
Thank you. The way I had it disabled left me without a Speedo, odometer stopped working as well as dcs, cruse control and various check engine lights.
Old Jul 27, 2013 | 04:01 PM
esfreerider
A reduction in sensitivity may even be preferable to me. I didn't know that was possible.
GAT
Oct 4, 2015 07:27 PM
eddyjoe
Oct 1, 2015 05:09 PM
Tires, Wheels & Brakes
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
rikaro
Sep 30, 2015 09:33 PM
