Turn Signal help !
Old Jul 9, 2013 | 02:25 PM
want2yak's Avatar
want2yak
Turn Signal help !
Hey There
I have an 07 Mini s and was wondering if someone can tell me where the Flasher relay is located . All my lights are working but turn signals are flashing really fast . I do get the idiot light when I start the car for an outside light problem out ? Any help with this would be great .
Old Jul 9, 2013 | 03:28 PM
rkw's Avatar
rkw
There is no flasher relay. The computer directly turns the bulbs on and off to flash them (and the turn click comes from a speaker).
Fast flash means a bulb out is detected. This is corroborated by your warning light. Did it always do that? By any chance, were any of the turn bulbs replaced with an LED bulb?
Old Jul 29, 2013 | 08:15 PM
"Gumball"'s Avatar
"Gumball"
Hey.... I would like to replace the bulbs with LED... but I know I will run into the "Fast Flasher" problem due to low resistance. Is there a fix for this? I have a 2006 MCS R52 and 2007 MSC.
Old Jul 29, 2013 | 08:58 PM
"Gumball"'s Avatar
"Gumball"
... any fixes other than splicing in load resistors!
Old Jul 30, 2013 | 04:34 AM
yetti96's Avatar
yetti96
Buy CanBus compatible LEDs from a reputable source and/or get the bulb error check codded out of your car via NCS.
Old Jul 30, 2013 | 07:25 PM
"Gumball"'s Avatar
"Gumball"
Any suggestions on a reputable source for CanBus LED's? Also - I am new to forums - what is NCS for getting the error check code out of the car?
Old Jul 30, 2013 | 07:38 PM
danjreed's Avatar
danjreed
https://www.northamericanmotoring.co...ights-r55.html
I just got these at my local parts store.
That or I also use http://www.superbrightleds.com/cat/l...acement-bulbs/ without issue.. make sure they are CANBUS error free (ie, they have the resistor built in.)
Old Jul 31, 2013 | 03:52 AM
yetti96's Avatar
yetti96
http://www.vleds.com/
http://www.oznium.com/car-lighting
etc
I don't trust crappy looking site or sites I haven't bought from before.
As far as seeing what others have used and learning more about NCS, I would polity say search...read the forums and see what others have done and what worked for them as many people have taken different avenues to get the same results.
Old Jul 31, 2013 | 08:19 AM
"Gumball"'s Avatar
"Gumball"
What is NCS?
Old Jul 31, 2013 | 01:34 PM
danjreed's Avatar
danjreed
What is NCS?
(Ok, I forget what it stands for..' New coding system?')
But its BMW/Mini's computer language used to control items in the car..
With a few software packages and a e-bay cable you can "hack" your Mini to do things it was never meant to do from the factory (US).
https://www.northamericanmotoring.co...beginners.html
Old Jul 31, 2013 | 09:14 PM
"Gumball"'s Avatar
"Gumball"
Thanks... I will read up on it!
UncDeo
Nov 4, 2019 04:08 AM
rob&JCW
Feb 21, 2018 02:41 PM
molala
Oct 2, 2015 01:53 PM
HogWldFLTR
Sep 8, 2015 05:25 AM
Suspension Products
Sep 2, 2015 10:32 AM
