Passenger side door will not open from outside
Old Jun 30, 2013 | 04:17 PM
ijourneaux's Avatar
ijourneaux
I finally have some time to try and get my passenger side door to work correctly.
I replaced the Bowden cable from the inside door handle to the latch mechanism. That seemed to fixe the problem I was having trying to open the door from the inside but now I can't get eh outside door pull to work.
After I got everything back together the first time, I thought everything was working but once the door locks, you can't open the door from the outside whether the door is locked or unlocked.
A couple of questions.
1. Does it matter how the cable from the exterior door pull is routed on its way to the door latch mechanism? It seems that it has to come through the door and do a 270 degree loop upwards so that the cable enters the door latch vertically from the top.
2. I have attached a picture of the end of the door pull cable showing that the interior plastic liner has pulled out of the guide by about 1/4in. Could that be the problem?
What I am missing? I would love to get the inside door cover back on.
Back to rereading the various threads to see if I missed something.
Ian
Edit: It is definitely something to do with the exterior handle. If I disconnect the exterior handle cable, THe door handle works correctly from the inside. Locks, unlocks, opes door.
If the exterior handle cable is hooked up, the minute the door is locked, the door can not be opened from the inside or outside. I have to reach into the door latch mechanism and release the exterior door cable. THen I can open the door
Attached Thumbnails Passenger side door will not open from outside-2013-06-30-17.59.56.jpg
Old Jul 2, 2013 | 08:36 AM
Nitro Jake's Avatar
Nitro Jake
manually move the latch mechanism that attaches to the exterior door handle. if this opens the door, then you know you've got a door handle (cable) problem.
Old Jul 2, 2013 | 09:19 AM
ijourneaux's Avatar
ijourneaux
If I reach in the pull the lever down, the door does open. SO it is a door handle cable issue.
Does the cover just snap off of the door handle so you can just replace the cable or do you have to repalce the door handle?
Thanks for taking the time to respond.
Ian
Old Jul 2, 2013 | 03:46 PM
Nitro Jake's Avatar
Nitro Jake
you cannot replace the outside door cable without the handle. there are 2 allen head bolts to remove the whole assembly. they're like $60 i think?
sevin
May 2, 2026 06:11 AM
Kimolaoha
Jul 5, 2023 01:04 PM
boostedhaze
Jan 2, 2018 07:26 PM
Lex2008
Aug 31, 2015 12:12 PM
polotska
Aug 23, 2015 03:03 PM
