Desperate Need Of Help!!!
Old Jun 30, 2013 | 09:51 AM
raindizzle's Avatar
raindizzle
Hi All,
I am in desperate need of help. About 3.5 weeks ago I was driving on the freeway here in CA when I totally lost power to the engine. A yellow blinking check engine light came on right after. I had taken it to Mini Corsa the following day. They had told me that my cylinder head had blown due to massive carbon build up, i had oil leaks around the valve cover due to a crack, and gasket needed to be replaced. They said that the problem was due to the bsh catch can that had been installed. They had replaced the whole cylinder head, valve cover, gasket, plugs, and etc...I had picked up my car about 1.5 weeks after I had brought it in. Everything was fine but was still having a yellow check engine light with a p115c code. I brought my car back to them few days after receiving it and they had replaced the MAF. After taking my car back and driving it, I still had the p115c code. Brought it back in and they had changed the recirculating valve due to a tear in the diaphragm, did an ecu update, checked all tubes for leaks and etc...Took the car back after all and still check engine light with the p115c code. I don't know what else can be the problem, and they don't know what else could it be. Can someone please help me out? Forgot to mention that after they had replaced the whole cylinder head they had removed the catch can and the boost tap. My car is totally back to stock and air filter has been replaced. What else can cause my car to still have a p115c code?
Old Jun 30, 2013 | 12:06 PM
Mini2na's Avatar
Mini2na
Will be watching this thread for answers.
Did they say why a BSH Catch Can would cause such a huge problem? Had it been emptied regularly?
Old Jun 30, 2013 | 02:06 PM
raindizzle's Avatar
raindizzle
Yes my catch can was always emptied after every gas fill up. I had forgotten what he had said to me about it but it did make sense when he explained it. If I go back to him I will get that explanation and write it down. I just remembered that with the boost tap installed it built the pressure into my cylinder head which then messed everything up.
Old Jun 30, 2013 | 02:09 PM
EHans's Avatar
EHans
Just curious... what model, year, mileage?
Old Jun 30, 2013 | 03:53 PM
jamez's Avatar
jamez
While I can't help you with the code or your situation I'm here regarding the BSH OCC.
Who here believes that an OCC could possibly have anything to do with that??
I'm no expert - and I have a BSH - but I fail to see how the extra volume of air to catch and condense the oil vapor could lead to anything but less buildup (isn't that the whole concept?!). Interestingly, when I had the dealer install a new engine they didn't but my OCC back in either.
I'm sorry for your troubles, good luck with finding a resolution.
Old Jun 30, 2013 | 05:06 PM
raindizzle's Avatar
raindizzle
2007 r56 mini cooper s june build with 79,352 miles
Old Jun 30, 2013 | 05:08 PM
raindizzle's Avatar
raindizzle
If you search the forum on the occ there are quite a few post from members who have similar issues.
Old Jul 3, 2013 | 08:43 AM
raindizzle's Avatar
raindizzle
OK I found out that it is something electrical that is causing the code! What electrical thing would cause a p115c code besides the bypass valve and maf?
Old Jul 3, 2013 | 10:49 AM
cristo's Avatar
cristo
Alliance Member
If the orginal problem was carbon build up, then the oil catch can probably delayed the onset
of the problem rather than causing it. Unfortunately, that put it into the post-warranty period.
Old Jul 6, 2013 | 02:29 PM
oldbrokenwind's Avatar
oldbrokenwind
I wouldn't blame the OCC for your oil leak problems, but blocking the rear vent with a boost tap can cause excess pressure build-up in the crankcase / valve cover area --- oil leaks. A lot depends on your driving habits --- which of the two vents is in use most of the time. I'm in process of checking out my dual OCC install --- to see if this fixes my back pressure & oil use problem.
Can't help with your code issues.
mni928
Oct 11, 2015 07:37 PM
mini-licious!
Jun 21, 2006 03:15 PM
paulmon
Tires, Wheels, & Brakes
22
Apr 27, 2006 07:06 PM
