how many sensors?
Old Jun 30, 2013 | 12:48 AM
genik's Avatar
genik
how many sensors?
How many sensors are there in the minis engine and where are they located?
Old Jun 30, 2013 | 03:16 AM
robbo mcs's Avatar
robbo mcs
Lots!!
I run a JCW rally car and try to carry most of the common sensors as spare parts.
By "engine" I presume you mean engine and associated parts.
Off the top of my head some of the more common and potentially troublesome ones
  • antiknock sensor
  • water temperature sensor
  • intake air temp sensor
  • combined boost pressure / temp sensor
  • manifold pressure sensor
  • lambda / O2 (multiple)
  • crank position
  • throttle position / throttle body position
  • fuel pressure
There are lots more. If I log on with my software I can monitor dozens of parameters in real time.
Why do you want to know?
Old Jun 30, 2013 | 05:00 AM
genik's Avatar
genik
Cause some time ago i had an issue with loss of power around 4000rpm, there seemed to be loss of overboost, changed the map sensor and all worked back to normal. But i think there are two map sensors... right? One after the turbo and one before
Old Jul 1, 2013 | 01:08 AM
robbo mcs's Avatar
robbo mcs
There are at least two pressure sensors, at least on mine, which is a euro spec N14 JCW
One is temp / pressure sensor, part 5 on this diagram, post turbo
http://realoem.com/bmw/showparts.do?...06&hg=13&fg=20
Second is inlet pressure sensor, part 10 on this page, pre turbo
http://realoem.com/bmw/showparts.do?...33&hg=11&fg=40
Old Jul 1, 2013 | 01:43 PM
genik's Avatar
genik
Are those two called Manifold Absolute Pressure sensors? Also known as m.a.p?
shorenetworks
Nov 4, 2019 06:18 PM
CRC
Dec 26, 2015 11:30 AM
sempaipaul
Sep 18, 2015 03:05 PM
Doc Pain
Sep 15, 2015 11:31 PM
Sep 14, 2015 12:48 PM
