is my oil pressure too low
Old Jun 29, 2013 | 12:47 PM
05 sd mcs's Avatar
05 sd mcs
I have an 05 MCS. just bought it a couple weeks ago. It has the gauge pack with the oil pressure and oil temperature gauges. at idle its only reading around 7 PSI, at cruising it is around 45 PSI, and goes up a little higher under acceleration. the low oil light has never turned on but I'm thinking that 7 PSI is way lower than it should be. sorry if this has already been discussed. I spent the past few hours searching and couldn't find any answers. any help would be appreciated.
Old Jun 29, 2013 | 05:25 PM
philnjean's Avatar
philnjean
Sounds a little low to me but cars run very light oil these days so it might be ok. Could be the gauge.
Old Jun 29, 2013 | 08:49 PM
astroBlackMetallic_Mini's Avatar
I put a gauge in mine. Those numbers are normal. No worries dude!
Old Jul 1, 2013 | 08:49 AM
quikmni's Avatar
quikmni
The oil pressure on my 2003 MCS and 2006 MCS has always run very low at idle with hot oil. I think the light does not come on until around 3-5 psi. I would not worry about 7 psi at idle. Your cruising oil pressure seems fine.
Kimolaoha
Jul 5, 2023 01:04 PM
TREX
Nov 2, 2019 07:31 PM
JamJam43087
Aug 16, 2015 02:02 PM
Emnotek
Aug 13, 2015 05:47 PM
