R50/53 I really need help!!!! Going mad!!!
Old Jun 19, 2013 | 01:50 PM
StephHouston's Avatar
StephHouston
Ok so I have a 2004 mini cooper and my stick shift cables went out. I had them replaced along with the stick itself and now the car wont start. We put it on the computer and the computer is saying that it needs a memory reset. The dealership is saying that they do not do memory resets for that years model. Have spent hours looking online and cannot figure out what the problem is! COULD ANYONE HELP ME PLEASE!!!
Old Jun 19, 2013 | 02:18 PM
Tab32's Avatar
Tab32
Do an ecu reset? Not really sure how shift cables would mess with that unless they were installed wrong.
Old Jun 19, 2013 | 02:24 PM
StephHouston
We tried the ECU reset and that has not worked
Old Jun 19, 2013 | 02:25 PM
StephHouston
We will try taking the batterey off for a minute and try the ECU reset again
Old Jun 19, 2013 | 02:41 PM
StephHouston
Getting all the way to the end on the ECU reset...it makes the noise on the gauges and the sound but after that the lights don't come on.....SO FRUSTRATED!!! Do I need a new ECU???
Old Jun 19, 2013 | 02:50 PM
SniperDetailing's Avatar
SniperDetailing
maybe check to make sure they didn't bump the YAW sensor that is located right behind the E-brake handle.
Old Jun 19, 2013 | 02:58 PM
StephHouston
what is the YAW and where is the E-brake handle?
Old Jun 19, 2013 | 03:05 PM
StephHouston
ok never mind on my stupid question
Old Jun 19, 2013 | 03:07 PM
StephHouston
It could not be in the E brake because that wasnt messed with...
Old Jun 19, 2013 | 03:13 PM
AlexQS's Avatar
AlexQS
Originally Posted by StephHouston
and now the car wont start. We put it on the computer :
Not sure what kind of computer you've hooked up to. Are there any Codes you can pull?
Old Jun 19, 2013 | 03:15 PM
ZippyNH's Avatar
ZippyNH
The end of the shift cables is UNDER the e-brake handle.... By the shifter...
Old Jun 19, 2013 | 03:35 PM
StephHouston
Should I just take it to the dealership?
Old Jun 19, 2013 | 03:36 PM
StephHouston
Does anyone know of a mini cooper mechanic in Houston, TX?
Old Jun 19, 2013 | 05:15 PM
StephHouston
Thank all of you for your comments - I thought it would be a simple unanimous answer but I see it is beyond my knowledge...
Thanks Again
rob&JCW
Feb 21, 2018 02:41 PM
simo711
Oct 8, 2015 07:07 PM
fkrowland
Sep 30, 2015 10:30 AM
WhinyR53
Sep 30, 2015 07:36 AM
Andrew Namel
Sep 12, 2015 08:49 AM
