Suspension Rear Swaybar knock and clunck
Old Jun 19, 2013 | 06:22 AM
MikeHancho's Avatar
MikeHancho
I had my local dealer install a new NM rear sway bar, I love the way it makes the car handle, but there is a significant amount of racket happening in the back at low speeds (I suspect at high speeds to but to much ambient noise to hear.)
They said all parts are tight and properly installed. They also said that this is normal for all sway bars.
This doesn't really seem accurate. Anybody with the same problem or remedy?
Old Jun 19, 2013 | 08:15 AM
Helix13mini's Avatar
Helix13mini
It's not normal. Either they left something loose (like drop links) or the bushings are the wrong size for the bar.
Old Jun 20, 2013 | 02:20 PM
yanks4285's Avatar
yanks4285
Depending on which bushings you used, poly urethane bushings are always gonna be noisy.
Old Jun 22, 2013 | 11:31 AM
bigdog0826's Avatar
bigdog0826
Min CMS was doing the same thing this weekend. Mine was simple as a loose nut on the sway bar. Once tightened it was fine.
Old Jun 23, 2013 | 08:43 AM
kconner5's Avatar
kconner5
Mine has been doing it ever since I installed it 7 or 8k miles ago. Took it into the dealer and the response was that it was touching the bottom of the subframe. So I called up Jerry at NM ad he fabricated me two 3mm spacers to fit under the bushing and mounting holes so it will lift up the bar just enough to not hit the subframe. I'll let y'all know if that solves anything.
Kyle
Old Jun 23, 2013 | 07:58 PM
broussardc's Avatar
broussardc
Let me know how that works for you Kyle, I've got the same problem. --Christian
Old Jun 23, 2013 | 09:55 PM
MikeHancho's Avatar
MikeHancho
Turns out the dealer didn't tighten it properly, even after they said they checked it. NM is sending me spacers, but not sure ill need them now. Don't have the car right now because other dealer caused issues are being addressed. Last test drive though sound was gone.
Old Jun 24, 2013 | 04:15 AM
yetti96's Avatar
yetti96
I had a clunk in mine that showed up almost 5k miles after I installed it. It was the endlink slightly loose.
Old Jun 6, 2014 | 11:33 AM
tominizer's Avatar
tominizer
I'm looking into getting the NM rear sway for my Countryman as I had it on my '08 Clubman S. I was interested to hear what happened here.
I'm just going to throw this out there in case anyone is doing a search on the rear sway making noise and comes across this thread. On my Clubbie around the 3-4 year mark, the bushings holding the bar to the chassis had worn down not only on the inside but on the sides and the bar had some side to side play. This gave it a knocking sound that drove me nuts.
Also, a little hotrodder trick if you want to solve worn bushings is to wrap your bar with some electrical tape and re-install the old bushings in the interim until your new bushings arrive.
Cheers
Old Jun 6, 2014 | 12:01 PM
Elmj's Avatar
Elmj
Same here just had it dealt with today
MasterShaftner
Sep 1, 2017 07:23 PM
David.R53
Sep 1, 2015 06:49 PM
Marktheman
Aug 23, 2015 11:45 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
tag1260
Aug 5, 2015 04:27 AM
