R50/53 Crankshaft removal? Anyone?
Old Jun 3, 2013 | 11:30 AM
vox633's Avatar
vox633
Hi Guys,
So, i heard a couple months ago a scary *** noise.. took the mini to BMW. BMW says its conrod bearing.
So, i took the car apart, took the engine out, took the engine apart. Only harmonic dampener, crankshaft and pistons+rods left on the engine. I cannot find a manual anywhere on how to get the crankshaft out.
Basically here are the things i am trying to find out:
How do i get the crank out?
Bolts... do i need new bolts for everything in the crank case once i remove them?
Torque specs for said bolts?
I'm really at a loss here, bentley book doesn't even have crank removal.
Old Jun 3, 2013 | 12:08 PM
Pbadore's Avatar
Pbadore
You need to remove the bed plate. For a more complete shop manual buy a 2003 to 2005 Dodge Neon factory shop manual and read the 1.6 liter engine section. There will be lots of explanations that are not present in the Bentley Mini manual. Chrysler designed and
built the 1st generation Mini engine for BMW.
Old Jun 3, 2013 | 12:56 PM
vox633's Avatar
vox633
I found the manual, there isnt a lot of detail around the 1.6 crank removal.. as in.. none. Would the 2.0L SOHC be similar?
Old Jun 3, 2013 | 02:04 PM
Pbadore's Avatar
Pbadore
Go to page 9-42 in the 2003 Neon SX 2.0 Service Manual for a 19 step removal procedure with an illustration of the 1.6 liter engine crankshaft and bedplate.
The 2.0 Neon engine design is not identical in that it uses a belt driven camshaft not the Mini's chain drive. Both engines use bedplates to secure the crankshaft main bearings, however there are many different design details.
I have worked on and own both types ( 06 Cooper and 04 MCS ;9 2003 and 2004 SRT4).
Old Jun 4, 2013 | 05:54 AM
vox633's Avatar
vox633
Right you are! 9-44 for the bolt sequence as well.
Thank you! That was of amazing help.
Old Jun 4, 2013 | 10:41 AM
jamez's Avatar
jamez
The 2007 BMW TIS also has some documentation on it as well.
Old Jun 4, 2013 | 11:01 AM
vox633's Avatar
vox633
I wish i had access to TIS. Jamez, is it possible for you to tell me if the bed pan and conrod bolts need to be replaced, and their torque specs?
Old Jun 5, 2013 | 02:37 AM
MINIFatherFigure's Avatar
MINIFatherFigure
From: Perth West Australia in an industrial unit with my numerous cars.
Inspect the bolts. If they have a thinner area between the head and the thread - replace. If they are even full diameter then they are probably re-useable. cannot assist with torque - sorry.
Old Jun 5, 2013 | 06:03 AM
Braminator's Avatar
Braminator
Here is to help you with some of your needs. These apply to R50-R53 models.
Old Jun 5, 2013 | 06:09 AM
Braminator's Avatar
Braminator
MINI - R50-R53 - Torque Wrench Setting
http://www.minitorque.com/forum/f275...settings-5915/
The_Kid
Nov 3, 2016 06:30 PM
Crimguy
Sep 10, 2015 01:07 PM
Sep 2, 2015 09:05 AM
greekzilla
Aug 23, 2015 03:44 PM
Aug 21, 2015 10:41 AM
