Suspension Sway bar question (hsport)
Old May 31, 2013 | 12:48 AM
scoopy's Avatar
scoopy
Hi i bought an hsport rear comp sway bar. Would just like to ask if thw sway bar is touching on the body near the sway bar bushings? In a addition, would like to also ask if the sway bar is interchangeable like at the end of the sway bar there is a part number should it be in the driver or passenger side? Im hearing a really bad squeaking grinding noise i have checked it with a mechanic and i have retighten all the bolts but the sound is still there thanks
Old May 31, 2013 | 04:08 AM
yetti96's Avatar
yetti96
I believe it is symmetrical and can go either way, but look closely at the installation pics. I think I made my have the text for the serial number face, right-side up so you could read it through the wheel spokes.
Mine does rub the body just a hair in a couple of places where the body panel seams are folded and welded together. It's hard to explain and I did have a bit of paint get scraped, but there is not enough rubbing to hear it or know there is metal on metal.
I did get a clunk after 3-4k miles. One of my end links was not tight enough.
Old May 31, 2013 | 04:15 AM
CHKMINI's Avatar
CHKMINI
Did you lube the bar using the lube supplied with the bar when installed? Mine (25mm completion bar) does not rub any body work on my R58 JCW.
Old May 31, 2013 | 05:19 AM
N2MINI's Avatar
N2MINI
Mine doesn't rub and it's been on for over 100,000 miles...also have never had to re-lube the fittings.. Pretty sure it doesn't matter which way you install it, but mine had a H-Sport sticker on it so I put it in right side up of course..
Old May 31, 2013 | 05:54 AM
scoopy's Avatar
scoopy
Actually it is like a squeaking sound. I got the comp bar used that is why theres not lube. Should i lube the bushing or the whole bar? Funny thing it rained awhile ago and the sound goes away but after a few miles the sound came back. Will check again tomorrow. So i dont need to switch the swaybar because the part number in mine is upside down hehe
Old May 31, 2013 | 07:21 AM
N2MINI's Avatar
N2MINI
I would try lubing everything back under there that moves to try to fix the squeak. Some sway bars have grease fittings. You could also buy some spray lithium grease for the areas with no fitting
Old May 31, 2013 | 07:22 AM
v10climber's Avatar
v10climber
You just need to lube where the sway bar contacts the bushings
Old May 31, 2013 | 07:47 AM
scoopy's Avatar
scoopy
Old May 31, 2013 | 08:00 AM
scoopy's Avatar
scoopy
i will try to lube the bushings tomorrow. so it is ok that the bar is rubbing the body?
Old May 31, 2013 | 09:18 AM
N2MINI's Avatar
N2MINI
you'd prefer it not too.. Don't want anything that moves to be obstructed ideally...
Lube anything that has a bushing back there while you are under there. Endlinks, top and bottom coilspring mounts etc. that could be giving you the squeak..
Old May 31, 2013 | 09:26 AM
scoopy's Avatar
scoopy
will redo all the bolts that the mechanic removed yesterday and also put a lube there. the squeak is kinda irritating hehe
Old May 31, 2013 | 09:34 AM
N2MINI's Avatar
N2MINI
My front coilovers squeak as well from time to time and I spray the top and bottom perches as best I can with the lithium grease and fixes it..
Old May 31, 2013 | 09:37 AM
scoopy's Avatar
scoopy
will try to remove the shocks and the rear stab link. and will try to move the swaybars hopefully i can replicate the sound hehe...
Old May 31, 2013 | 09:51 AM
LTLMCPE's Avatar
LTLMCPE
I'd totally forgotten it happened until reading this, but mine had a squeek too after install. It was on the driver's side and just needed some additional lube. It's the comp bar.
Old May 31, 2013 | 10:07 AM
scoopy's Avatar
scoopy
lube in the inner and outer bushing? do i need the lube from hsport?
Old May 31, 2013 | 11:50 AM
quikmni's Avatar
quikmni
The H-Sport bushing should have a zerk fitting to add lube. Need to use a lube that is compatible with the bushing material and water proof such as Sta-Lube or Green Grease.
You do not want the sway bar hitting anything because it could bind up and cause a real problem such as massive oversteer.
Old May 31, 2013 | 08:18 PM
scoopy's Avatar
scoopy
What is the zerk fitting? Sorry
Old Jun 1, 2013 | 03:05 AM
N2MINI's Avatar
N2MINI
it's the fitting that the grease gun will attach to, to push in the grease at the bushing inside..
Old Jun 1, 2013 | 03:18 AM
scoopy's Avatar
scoopy
Oh ok. We already pulled it out again and put some grease on the bushings and the middle bar. In addition, we move the stab bushing clamp forward i hope that will help hehe... In addition does the ride gets stiffer when u put swaybars
Old Jun 1, 2013 | 06:58 AM
N2MINI's Avatar
N2MINI
Not when your going straight!!!
Old Jun 1, 2013 | 09:46 AM
scoopy's Avatar
scoopy
Well it squeaks again. Will try to do it again and check for the scratches in the swaybar. It seems the sound is comimg in the middle of the bar. The one touching in the body. The mechanic told me i can put some washers in the bolt in the subframe so there will be clearance for the swaybar but im hesitant to do it hehe...
Old Jun 2, 2013 | 05:21 AM
N2MINI's Avatar
N2MINI
Have a friend do the same thing. Do it. No problems.
Old Jun 2, 2013 | 05:26 AM
scoopy's Avatar
scoopy
Ok i guess will just do that hehe
Old Jun 2, 2013 | 07:13 AM
scoopy's Avatar
scoopy
What is your friend's sway bar?
Old Jun 3, 2013 | 08:04 AM
N2MINI's Avatar
N2MINI
H-Sport
