R50/53 Taking off Bonnet Stripes?
Old Apr 27, 2004 | 01:29 PM
ZeremiaH's Avatar
ZeremiaH
Still new here, but has anybody taken off there Bonnet Stripes?? and if they have, has it left a residue behind on the bonnet/hood? Like sticker lines? Or lines? or were the paint is lighter under the sticker? I have a 04 Pepper White that I bought back in Nov. So the paint is not to old… Thanks for any info you can give.
Old May 2, 2004 | 10:24 PM
JohnNC's Avatar
JohnNC
Hello to you. Just purchased my Mini Cooper a couple of weeks ago and mine is pepper white as well. Mine has no stripes so how about us swapping bonnets haha
Old May 2, 2004 | 10:44 PM
kenchan's Avatar
kenchan
Use a hairdryer or heatgun to start off the edge of the stripe.
Then peel back slowly. If there is adhesive or residue left on the
bonnet, use some GooGone on a soft t-shirt and rub away. Don't
use papertowels.
I would then use claybar to remove any residue left on the bonnet,
(ScratchX if it still doesn't come off) then finish off with wax.
Light colors like silver and white will probably show no sign of
fading especially in only 6-7months.
Old May 2, 2004 | 10:46 PM
kenchan's Avatar
kenchan
btw, its a good idea to wash off the GooGone with car shampoo before you
do the claybar.
Old May 6, 2004 | 04:35 PM
pocketrocketowner's Avatar
pocketrocketowner
I attack gluey residues of any kind with WD-40......I will try Goo-Gone see if it is better....BTY, Goo-gone is the best cleaner of everything i have run into, specially the high test smelly kind.....
pocketrocketowner
I attack gluey residues of any kind with WD-40......I will try Goo-Gone see if it is better....BTW, Goo-gone is the best cleaner of everything i have run into, specially the high test smelly kind.....
Old May 6, 2004 | 04:47 PM
1REDMINI's Avatar
1REDMINI
I'd stay away from heat guns, but a hairdryer shlould do the trick to get it started. 3M makes a spray called something like "Woodgrain & Stripe Remover" that works very fast and won't damage the paint. Mask off the rest of the hood before you spray however since the stuff is messy. 3M also makes a spray cleaner to remove the remover that while more expensive than Goo Gone or WD40, it won't harm the paint and won't require clay barring and additional cleaning.
Old May 7, 2004 | 03:08 AM
pocketrocketowner
but wd40 harms nothing.....I have been using it in my race cars (race cars have lots of stickers) for years and it works a treat.......I swear...... :smile:
caiken
Aug 27, 2015 06:55 AM
Drumsound
Aug 25, 2015 02:25 PM
minicoclub
Aug 25, 2015 09:07 AM
bctf1
Aug 6, 2015 12:55 PM
