R56 I know my car eats a bit of oil but...
Old May 30, 2013 | 07:42 AM
t-bear's Avatar
t-bear
I have had my 2007 Mini Cooper S for about a year and a half now.
Generally I check my oil every 1,000 miles and put about 1/2 quart into her.
This last time it took a whole quart.
I am thinking I will start check the oil every 500 miles.
Is this normal or should I be worried!
No Leaks or problems that I know of.
Old May 30, 2013 | 07:45 AM
quikmni's Avatar
quikmni
It is normal according to MINI.
However, I think that it is wrong for MINI to argue that burning a quart of oil every 500-1000 miles is normal.
Old May 30, 2013 | 08:02 AM
DneprDave's Avatar
DneprDave
A quart every 1000 miles is considered acceptable by all car manufacturers. Every 500 miles, would be excessive.
Dave
Old May 30, 2013 | 09:26 AM
mbwicz's Avatar
mbwicz
I normally check my oil every week (about 300 miles), and used to put in 1/4-1/2 quart every week. I read in another thread to let the oil get lower on the dipstick to reduce consumption, and that works for me. Instead of me topping it to the upper bulb on the dipstick, I only bring it 1/2 way between the top and lower bulb. just by making that change, my oil consumption has dropped to about 1/2 quart every 1000 miles.
I feel comfortable doing this because I check the oil frequently.
I also replaced my valve cover recently, this was a pretty significant leak at several places around the cylinder head.
Mike
countryboyshane's Avatar
countryboyshane
That is very bad.
I would honestly think about selling or trading in your car. You've got a sloppily built engine.
Old May 30, 2013 | 09:47 AM
Karl Childers Lovechild's Avatar
What oil are you running?
Old May 30, 2013 | 09:56 AM
rockridge's Avatar
rockridge
My car is also a 2007 MCS with low mileage (26,000), that I have owned since new. I check the oil level once a month, and have the oil changed once a year, and have never had to top it off.
Old May 30, 2013 | 01:25 PM
Velocityvic's Avatar
Velocityvic
I check the oil every time i get gas just like in the old days when a gas station was a service station.
Old May 30, 2013 | 01:29 PM
ressler's Avatar
ressler
i had to put oil in my mini 2008 clubman s with 60,000 miles every week i had oil lines replaced all of a sudden i was losing power and then this huge atomic bomb came out the back of the car. i got it home. my mechanic changed some more lines and i traded it for a new one
Old May 30, 2013 | 02:32 PM
jordan.burks's Avatar
jordan.burks
I have a 07 MCS with 51000 miles and I add about a quart every 1000 miles. doesnt really bother me, i kinda drive it hard.
Old May 30, 2013 | 03:13 PM
Salbotehcow's Avatar
Salbotehcow
I have a 07 MCS with 35,000 miles and I add a quart every 1000 miles too. I also enjoy driving my car very spiritedly. I'm running Royal Purple 5w30. I Change the oil every 7k.
Old May 30, 2013 | 03:21 PM
Velocityvic
My 08 has 92,000 miles on it and depending on how hard I drive, I add about half a quart of oil per tank of gas.
Old May 30, 2013 | 06:03 PM
nrfitchett4's Avatar
nrfitchett4
only had my mini about a month, filled up twice. Checked oil each time and so far its still full. Oil is a little dirty, not sure how old though the tag says to change @ 65k. Might do it a little sooner just so I know how many miles are on the oil.
Old May 30, 2013 | 06:35 PM
Ch28Kid's Avatar
Ch28Kid
I have a 07 MCS with 37000 miles and I put 1 q every 800 miles. I'm using RP 5w30 but I do notice it consumes a lot more oil after tune. Don't know if that is normal.
Old May 30, 2013 | 07:44 PM
danjreed's Avatar
danjreed
Check the PCV... A stuck PCV when mingled with a turbo will suck a ton of oil into the intake.
Old May 31, 2013 | 12:51 AM
rhygin's Avatar
rhygin
I have to say this matches my experience, roughly. Changing the oil every 5 or 6k, I find that the oil quickly (in few weeks) drops to 1/2 way between the bulbs and then stabilizes. I check every other fill-up or so, and haven't had to add oil between changes.
Old May 31, 2013 | 01:28 AM
Creeve's Avatar
Creeve
$10 says the turbo oil feed line is leaking.
Old May 31, 2013 | 07:15 AM
Velocityvic
Had my oil feed line to the turbo and the oil filter housing replaced when I had the timing chain work done.
Getrieben
Sep 12, 2024 07:03 AM
Getrieben
Aug 17, 2016 06:32 AM
xpunisherx
Aug 10, 2015 10:50 PM
ludedude
Aug 10, 2015 07:16 PM
