R50/53 Antenna: What part do I need to replace?
Old May 27, 2013 | 07:58 PM
isedawishy's Avatar
isedawishy
Hello,
Bought the car with a messed up antenna and I am not sure which portion I need to replace.
I know I at least need the antenna itself and the cover, but do I need all the guts too? I cannot tell if the base broke or if the OEM antenna broke.
Old May 28, 2013 | 11:47 AM
AlexQS's Avatar
AlexQS
Originally Posted by isedawishy
Hello,
I've not had the cover off mine, so not absolutely sure.
You might look at http://realoem.com/bmw/. Put in your make, model, etc, then you can browse the catalog of parts with diagrams. -Looks like there's more than one antenna, so you should check what it shows for your production month/year.
Just a guess, but it looks like the base of yours is broken. Looks like the part that would have the female thread to accept the antenna is taller in the diagram than in your photo.
Attached Thumbnails Antenna: What part do I need to replace?-image-1508538575.jpg
Old May 28, 2013 | 11:51 AM
AlexQS's Avatar
AlexQS
Ps. I hope I'm wrong, would be great if your base isn't broken. If you put a pair of pliers on the part sticking out, will it unscrew? If its already broken, couldn't hurt.
Old May 28, 2013 | 01:59 PM
isedawishy's Avatar
isedawishy
Thanks for the reply.
I found this pic. It looks like the threaded stud is what snapped. I'm not sure I can turn it since I can't really tell how it's mounted on.
It's just weird how it's broke and it looks like it's made for a philips head.
Old May 28, 2013 | 04:18 PM
miniconcarne's Avatar
miniconcarne
What year Mini is it? Looks like an 02-04, if so great, if newer these are very difficult. Headliner needs to be dropped on late 04 and on models. Good luck.
Old May 28, 2013 | 04:52 PM
isedawishy's Avatar
isedawishy
Its an 03. Do you think I need to replace everything?
Old May 29, 2013 | 04:52 PM
miniconcarne
Not sure, gonna pull my '03 apart and see what is what. I'll get back to you.
Old May 30, 2013 | 07:58 PM
isedawishy's Avatar
isedawishy
Did you have a chance to take a look?
eliseo1981
Jan 28, 2021 02:45 PM
kpl
Aug 11, 2015 04:52 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
