Suspension GP2 owner looking for suspension upgrades
Old May 23, 2013 | 09:36 AM
Inkw8ll's Avatar
Inkw8ll
Hello all, I'm new to the world of MINI & understand this car to be more of a handling vehicle vs a powerhouse. Can you direct me to some useful links on suspension upgrades, not just coilovers &/or springs/shocks. I almost have my mind made up with Ohlins coilovers (from past experience with VWs & a thread on this being a great compromise between track & street), but I'm open to suggestions. I'm not looking to go super low (I live in NYC) & it will not just be for looks. I would like to try an AutoX event twice a year.
My main concern are other parts of the suspension upgrades. What's available, where should I start my search?
Old May 23, 2013 | 09:43 AM
SuperGreg's Avatar
SuperGreg
Not sure I understand the Q. If you have a GP2, you already have a very high end suspension.
Old May 23, 2013 | 10:05 AM
Braminator's Avatar
Braminator
You have the best all around suspension that MINI ever put on a MINI and you want to change it? IMO spend the money on a driving school. The experience you gain there will out weight anything you to do your MINI again IMO.
Old May 23, 2013 | 10:18 AM
Inkw8ll's Avatar
Inkw8ll
There's no room for improvement?
Old May 23, 2013 | 10:21 AM
Braminator's Avatar
Braminator
Add a larger rear sway bar, change to all poly bushings and add adjustable rear control arms.
Old May 23, 2013 | 10:30 AM
Inkw8ll's Avatar
Inkw8ll
Thank you for the starting point? Any brand suggestions?
Old May 23, 2013 | 10:38 AM
Braminator's Avatar
Braminator
Powerflex bushings, Hotchkis Sport 4 piece Rear Camber Link set(lca), and NM Adjustable 22mm Rear Sway Bar
Old May 24, 2013 | 02:52 PM
mbwicz's Avatar
mbwicz
Inkw8ll,
I recommend that you contact Way Motor Works. He has a GP, so will be able to relate to any comments that you have. You should drive the car for a while to see what you don't like, or what you want to improve. More grip, less body roll, more stiffness, what do you want?
Braminator is right, you have the car with the latest and greatest MINI suspension yet. That doesn't mean that you cant personalize it.
Mike
Old May 24, 2013 | 03:47 PM
Inkw8ll's Avatar
Inkw8ll
Originally Posted by mbwicz
Inkw8ll,
Mike
Thank you, I've placed a few orders with WMW, but have not spoken to him yet in regards. I'll take your advice in regards.
Old May 24, 2013 | 04:10 PM
jkapinos's Avatar
jkapinos
I would add Vorshlag Camber plates to the stock coilovers. As well as a rear sway bar, adjustable end links, adjustable lower control arms to start. If not in love with the coilovers already on the car, then I would look at KW clubsports or V3's also Ohlins. I have Ohlins on my other car, but will go with the clubsports with the mini.
Old May 24, 2013 | 04:25 PM
Inkw8ll's Avatar
Inkw8ll
Those are some great ideas, I'll look into them
Old May 24, 2013 | 05:11 PM
minibx's Avatar
minibx
Inkw8ll, at the end of June ill be setting up an appointment at Helix, last time I was there they were working on a GP I'm sure that he can give you some cool ideas, call Eric he can help you decide what to do. Ill check with you if you want to tag along and see his shop I know that your schedule at work is challenging but it's a fun ride and he has a cool shop too lol also that other shop in queens or Brooklyn TyrolSport they have a good reputation as well as we talked about, I'm sure that they will give you good advise.
Old May 26, 2013 | 09:05 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
the Hsport Comp Sway bar and some Hsport rear lower control arms are the best 2 things to start with.
also the NM torque arm bushing.
But if you're not really tracking or AutoXing the car how much further do you really need to go? Don't get me wrong I'd love for you to buy a bunch of parts but if you're not going to use them save the money.
W0TM8
Dec 19, 2019 07:50 AM
Zettinger
Aug 25, 2015 04:04 PM
Ryan Conaway
Aug 18, 2015 07:45 AM
sabjcw
Aug 14, 2015 07:40 AM
