R56 HKS BOV Install Instructions?
Old May 19, 2013 | 02:25 PM
cheezehead's Avatar
cheezehead
Does anyone have a pdf or some instructions they could scan regarding installing the HKS BOV on an R56? please send to me if you do!
I want to remove mine and I need to figure out where this vacuum line or whatever is hooked up to it. I figured the directions would be a good start. I have searched all over and cant seem to find anything regarding the install of the HKS on to an R56.
thanks in advance!
Old May 19, 2013 | 04:04 PM
Kalibdor's Avatar
Kalibdor
If nobody else has the answer for you I will once I'm back home tomorrow morning. I believe I still have the instructions from when I had my HKS on. Easiest way to describe the whole process is you're re-installing the stock top 2/3 of the Air Charge Pipe, and plugging the MAP sensor directly back into it's port. All of the other stuff leaves with the HKS
Old May 19, 2013 | 04:19 PM
countryboyshane's Avatar
countryboyshane
The vacuum line is T-fitted into the MAP sensor port on the intake manifold.
Old May 19, 2013 | 05:04 PM
cheezehead's Avatar
cheezehead
thanks guys! yeah I would like to take a look at the instructions. I dont see it T fitted to the MAP sensor. it actually goes behind and below where the MAP is. thats my concern. Maybe whoever put this on originally did it differently? not really sure.
I can see the MAP as thats where I need to hook up the boost tap for the boost gauge and I dont see anything on it currently.
I will take some pictures as soon as my car cools down so you can see what I mean.
Old May 20, 2013 | 06:58 AM
countryboyshane
If they didn't use an adapter to tee it into the MAP, they probably drilled into the intake manifold, which is the worst way to do it.
Old May 20, 2013 | 09:22 AM
cheezehead's Avatar
cheezehead
it looks like there is a T adapter behind. couldnt get a good picture of it though..
Old May 20, 2013 | 10:35 AM
cheezehead's Avatar
cheezehead
Here's a pic i was able to get with my phone behind the manifold.. you can see the T adapter. the hose going to the BOV is the bottom one on the T.
Old May 20, 2013 | 10:34 PM
cheezehead's Avatar
cheezehead
so I guess my question is, since a T adapter is present, what can I do with this? can this be used for the boost gauge? do I just buy an adapter to remove the T and join the other 2 together?
The reason I ask about the boost gauge is there is a part to install at the MAP.
adrchn
Aug 13, 2019 02:11 AM
minimofo
Sep 9, 2015 10:29 AM
Mini'mon
Aug 26, 2015 01:02 PM
Super Coop
Aug 17, 2015 05:09 PM
