Coolant
Old May 18, 2013 | 12:12 PM
Mini-LSE's Avatar
Mini-LSE
Coolant
Does anyone have a recommendation on coolant or do I need to use the Mini brand? I went to the dealer and parts closed at 1pm on Saturdays.
Old May 18, 2013 | 12:24 PM
ZippyNH's Avatar
ZippyNH
Zerix g-05
Same formulation as mini/bmw...but hard to find...pep boys does carry it....but in my area, nh, bmw/mini is ACTUALLY CHEAPER.
Old May 18, 2013 | 12:48 PM
RobMuntean's Avatar
RobMuntean
Prestone 50/50 is good to use too.
Old May 18, 2013 | 01:01 PM
ZippyNH's Avatar
ZippyNH
Different stuff from mini/bmw blue....
is ok with a full flush....but still not the same to mix.
Old May 18, 2013 | 01:20 PM
RobMuntean's Avatar
RobMuntean
I thought he meant if he did a coolant flush what brand to use. That's what brand I always use. The "MINI coolant" is overrated. It's just to make you think otherwise IMO.
Old May 18, 2013 | 01:23 PM
ZippyNH's Avatar
ZippyNH
Thinking on a 3 month old 2013 he is topping off....
Old May 18, 2013 | 01:27 PM
ZippyNH's Avatar
ZippyNH
And mini/bmw DID update the coolant to "lifetime" or longlife when they switched from the old color jug to the new...old bmw was white jug, new is silver...not sure on mini,but same blue colour...compatible anyway.
Old May 18, 2013 | 02:33 PM
RobMuntean's Avatar
RobMuntean
I can't see his signature when I'm on my phone.
Old May 18, 2013 | 02:35 PM
Mini-LSE's Avatar
Mini-LSE
Thanks for the feedback. It is acutely my wife's 2010 R57. It is just below the min line.
Old May 21, 2013 | 01:36 AM
nrfitchett4's Avatar
nrfitchett4
Curious. I have a 2007 r56 s and the coolant is orange. I'm guessing this is aftermarket long life coolant. What color is the mini stuff?
Old May 21, 2013 | 02:12 AM
RobMuntean's Avatar
RobMuntean
Blue
Old May 21, 2013 | 03:37 AM
nrfitchett4
Blue
definitely not stock stuff then. Will keep an eye on temp warnings considering within a month we will be seeing 100+ more often than not...
Old May 21, 2013 | 05:00 AM
Post up a pic if you can, like they said above its blue.
http://www.ecstuning.com/Search/82140031133/ES196253/
Old May 21, 2013 | 06:15 AM
danjreed's Avatar
danjreed
Any coolant that is G48 spec is best. (Blue in color)
Its the factory stuff.
http://www.glysantin.com/files/basf_...iew_a4_e_1.pdf - Its what Mini/BMW ships with from the factory.
Everyone keeps draggin up the Zerex G05 stuff, which... is not the right stuff..
No, its not the same. Don't mix coolants.
If you just need a little - order this stuff, its 9$ for 1.5L. You mix it with 1.5L of distilled water.
http://www.germanautoparts.com/productdisplay/78014
Or of course the stuff ECS sells is perfect.
Old May 21, 2013 | 06:22 AM
danjreed's Avatar
danjreed
Zerix g-05
No, its not.
Its not the "same stuff" at all.
Old May 21, 2013 | 10:07 PM
nrfitchett4
Its orange, guessing the prestone coolant that works for 98% of the cars now. I will check on switching it out, guessing I can the flush and refill.
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
vulkandino
Oct 31, 2015 08:29 PM
navybsn
Oct 4, 2015 03:27 PM
point665
Sep 29, 2015 12:41 PM
silence2-38554
Sep 28, 2015 12:19 PM
