Time for new tires
Old May 18, 2013 | 11:42 AM
bucky's Avatar
bucky
Time for new tires
It's that time for new tires and I'm looking for suggestions. What does everyone enjoy for a good all season non run flat tire. I have the stock 195/55/16 tire size. Would you guys suggest getting something a little wider? What fits?
Old May 20, 2013 | 11:34 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
While there are quite a few Runflat choices for the MINI in 195/55-16 these days, most are summer tires.
For Ultra High Performance All Season runflats the tire of choice is-
Bridgestone Potenza RE960AS 400 treadwear
195/55-16 $141 each, 25 lbs
205/55-16 $138 each, taller sidewall allows more ride comfort than stock.
Tirerack test results for runflat tires-
http://www.tirerack.com/tires/tests/...y.jsp?ttid=164
Both sizes will fit the MINI OEM 16" wheel and suspension. If you have a lowered MINI then 195/55-16 gives more clearance since 205/55-16 is taller than stock at 24.9" tire diameter.
205/55-16 tire size will work, has a little more tread contact patch for more grip, has taller sidewall for comfort, is 3 lbs heavier and has more rolling resistance. In deep snow it is better to have a more narrow tire. Cost is nearly the same for each tire.
JamJam43087
Aug 16, 2015 02:02 PM
Rennfahrer555
Aug 13, 2015 09:07 AM
Dashdog
Aug 10, 2015 06:17 AM
tippin
Aug 5, 2015 08:43 AM
