CEL P2418 Evaporative Emission System Switching Valve Control Circuit/Open
Old May 16, 2013 | 07:59 PM
schor662's Avatar
schor662
I received the code P2418 "Evaporative Emission System Switching Valve Control Circuit/Open" this morning when starting up the car. Yesterday I had filled up the gas tank. Any idea if bad gas could cause this message, or does it actually require a repair? 53k on the odometer.
Thanks in advance.
Old May 16, 2013 | 08:20 PM
Braminator's Avatar
Braminator
Gas and a bad gas cap can throw codes sometime. What year is your MINI? Is it under warranty? If not it still might be covered as this is part of the emission systems. IMO I beleive you have at the leak diagnostic pump, and/or the EVAP solenoid valve as seen below. Here is what the system looks like.
Old May 16, 2013 | 08:22 PM
schor662's Avatar
schor662
It's a 2010 Mini Cooper S with 53,000 miles. Tried clearing the code tonight. Went right back on once I turned the car back on.
Old May 17, 2013 | 09:49 AM
Slave to Felines's Avatar
Slave to Felines
Double-check the gas cap.
Old Jun 7, 2013 | 06:32 AM
z85rado's Avatar
z85rado
did you get anywhere with this?
I had the same code this morning. a couple things i'm thinking could cause it. i filled the tank halfway with regular, caught it, finished with 93 and then a bottle of octane boost. second, i drove in heavy heavy rain/pooling water on my way home from work yesterday.
Old Mar 27, 2014 | 07:26 AM
Fred Heiler's Avatar
Fred Heiler
That's a good diagram, but I don't think it shows the purge valve or vent valve. Anyone know where it's located on a 2010 S Hardtop? I'm guessing it's near the throttle valve, but someone (maybe a different car) said under the intake manifol.
Old Jan 3, 2015 | 09:15 AM
illbegotten's Avatar
illbegotten
Did you ever find the fix for your code?
I have the same code and had a bad spot in a wire, fixed that but still have the light on.
theblackfalcon
Oct 11, 2015 09:49 AM
portedbuckle
Sep 11, 2015 07:02 AM
David.R53
Sep 1, 2015 06:49 PM
Emnotek
Aug 13, 2015 05:47 PM
