R50/53 Torx M10 X 13 Rear Brake
Old May 16, 2013 | 05:58 PM
ryanleeis's Avatar
ryanleeis
I removed the rear tire because of a knock on every rotation of the wheel and found that the wheel lugs where the only thing holding the disc to the wheel hub.. the TORX that holds the disc to the hub was broken off .. so now the remaining piece needs to be drilled out and replaced.. could someone point me in the right direction as to where I can pick up the Torx M10 X 13 soon? I'm in Canada
here is a picture below
Old May 16, 2013 | 06:04 PM
Braminator's Avatar
Braminator
Unless you are stressing that it is missing, IMO don't worry about it. All the torx screw does is secure the rotor for when you put the wheels on. It serves no real purpose other then that.
Old May 16, 2013 | 06:14 PM
ryanleeis's Avatar
ryanleeis
thank u I seems too be fine but I'd like to get the part .. do u know where I can get it?
Old May 16, 2013 | 06:48 PM
Braminator's Avatar
Braminator
Here is where to get them
http://www.ecstuning.com/Mini-2004-C...otors/ES16458/
aldito2
Nov 25, 2015 09:33 PM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
jpgwinn24
Tires, Wheels, & Brakes
Aug 23, 2015 02:53 PM
jpgwinn24
R55 :: Clubman Talk (2008+)
Aug 20, 2015 06:57 PM
