R50/53 No window movement when opening-shutting door.
Old May 14, 2013 | 06:19 PM
Kathy1946's Avatar
Kathy1946
Noticed when I open-shut the car door that the little window movement-blip wasn't there.
Then down the road I hit the toggle to lower the drivers side window and it didn't work. Thanks to Braminators post about the fuses and looking at a video, I popped the fuse cover near the drivers door. From what I can tell the fuse at f1 is good.
Any other thoughts on why the window-toggle doesn't work?
Kathy
Old May 14, 2013 | 06:29 PM
Braminator's Avatar
Braminator
You can try this:
Instructions
  • 1 Insert the keys and turn on the ignition. It does not matter whether you start it or not.
  • 2 Put the window all the way up (if you are able).
  • 3 Press and hold the window switch in the up position for 10 or more seconds. Do this with the door closed.
  • 4 Open the door to make sure the window drops as it should. Close the door to make sure it goes back up again.
Old May 14, 2013 | 07:10 PM
uromini's Avatar
uromini
This happened to me a week or so ago and bram's directions fixed it! Quick and easy..
Old May 14, 2013 | 07:29 PM
Kathy1946's Avatar
Kathy1946
Thanks Braminator.
I'll go try it.
Old May 14, 2013 | 07:49 PM
Kathy1946's Avatar
Kathy1946
Tried it. It didn't work.
Old May 14, 2013 | 08:16 PM
sdiver's Avatar
sdiver
Sounds like it could be a bad window motor. I had a similar symptoms a few years ago, and it was the window motor. If you give the area right above the speaker on the affected door a good knock, it may jolt the motor back to life for a bit. Only for a bit though...it'll need replacing.
Old May 14, 2013 | 08:39 PM
Braminator's Avatar
Braminator
This is the The FONZIE method. lol
Old May 15, 2013 | 06:42 AM
Kathy1946's Avatar
Kathy1946
Thanks sdiver.
Looked up a few things and it sounds like the motor most likely is the problem. I'll try the "knock" and see if that gives me a little more time.
Old May 15, 2013 | 09:11 AM
Yea,
If the window reset and the fonzie method don't work, looks like the window motor.
Can you hear the motor clicking at all when you press the window toggle switch, you will have to listen by the area you did the fonize test on. Just want to make sure the window regulator is not jammed.
Let us know.
Old May 15, 2013 | 10:18 AM
Kathy1946's Avatar
Kathy1946
Yea,
Let us know.
Yes, there's a slight click. I'll be taking it in soon. Was just a little freaked, remembering back to when the door wouldn't open. At that time I could at least roll the window down and reach the outside handle. This little car keeps me focused, just figuring out escape routes...
Old May 15, 2013 | 11:01 AM
What production month / year do you have there was a split year in 6/2005? I can show you the parts.
Thanks for the update.
Old May 15, 2013 | 01:21 PM
Kathy1946's Avatar
Kathy1946
Originally Posted by ecstuning
what production month / year do you have there was a split year in 6/2005? I can show you the parts.
07-29-2004
Old May 15, 2013 | 01:44 PM
Thanks, you did not mention which side, passenger or driver so here is both. You are in the years with production to 6/2005.
Left side ( driver ) Window Motor
http://www.ecstuning.com/Search/67626955875/
Left side ( Passenger ) Window Regulator
http://www.ecstuning.com/Search/51337039451/
Right side ( driver ) Window Motor
http://www.ecstuning.com/Search/67626955876/
Right side ( driver ) Window Regulator
http://www.ecstuning.com/Search/51337039452/
Old Jun 3, 2013 | 07:32 AM
Kathy1946's Avatar
Kathy1946
Just took my little car in for the window fix. Got my fingers crossed that everything goes right.
It's to hot to worry!!!
Old Jun 5, 2013 | 03:20 AM
MINIFatherFigure's Avatar
MINIFatherFigure
From: Perth West Australia in an industrial unit with my numerous cars.
I've been using the Fonzie Fix for about 2 years now. Can't see why I need to take it to bits if I can keep it working. As a fix it's Fast and Cheap. Guess what it is not..
Old Jun 5, 2013 | 04:38 AM
Braminator's Avatar
Braminator
Old Jun 5, 2013 | 08:08 AM
trinity5614's Avatar
trinity5614
Fonzie fix here also on the passenger side 03 MCS
Old Jun 5, 2013 | 09:58 AM
Kathy1946's Avatar
Kathy1946
All is fixed and at a fair price, considering the time it involved. However, I would have preferred the "Fonzie" fix, had it worked....
USNAE2
16
Jun 17, 2022 07:17 AM
bahman
Feb 14, 2016 10:29 AM
MINI Stupor
Oct 1, 2015 11:36 AM
Emnotek
Sep 29, 2015 07:37 AM
rt808
Sep 25, 2015 01:59 PM
