HELP Engine Rebuild!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old May 12, 2013 | 10:28 AM
R57Chiller's Avatar
R57Chiller
Hi MINI owners I am having a TAC error after I have resurfaced my cylinder head due to overheat warp and change the radiator pump and the thermostat housing with the thermostat, 2nd thing my radiator pump only turns when I turn the ignition on and the cars start and after like 10 seconds the radiator pump stops turning and overheat will occure. Please Guys advice me what to do?????? do I need to reprogram the car and all of this will be fixed or what???????????? the nearest mini workshop is like 400 miles away please help!!!!!!!!!!!!!!!!!!!!!!
2009 R57 non S
Old May 12, 2013 | 05:40 PM
boOst spIKe's Avatar
boOst spIKe
2009 R57 non S
I'd start with replacement of your friction wheel.
Old May 13, 2013 | 02:20 PM
alexs3d2's Avatar
alexs3d2
Yeah check your friction wheel and friction gear. The friction gear could be jammed from rubber debris. There is no electronic component controlling the water pump, so the computer can't be at fault.
danraabe
Aug 18, 2015 09:32 AM
skippermini
Aug 13, 2015 06:13 AM
wind715
Aug 11, 2015 07:56 AM
fm.illuminatus
Aug 10, 2015 12:15 AM
calebmil
Aug 7, 2015 05:54 AM
