R50/53 How hosed am I on our loved 2006-S.. rings?
Old May 9, 2013 | 07:25 PM
redmist's Avatar
redmist
So today I went out and activated the radio in the wifes Mini Cooper. It's a 2006 S with around 92,000 miles on it. I am very mechanical, and noticed the vacuum on her boost/vac gauge was at 10" at idle. I thought this was a little low.
Pulled dip stick, smells like gas!!!
So I pull the filler cap off the cover and start it up. It has a gas smell and enough blowby that I can feel the individual cylinder pulses as each one fires.
At this point I am to assume that the rings are gone, and it is in need of a re-ring at the least. I plan to do a compression check on it, and go from there.
I have not messed with this car other than all the routine maintenance, and I realize it's sorta high miles, but would you folks agree with my assumption? It does use a little oil as well. I never drive it, so I can't give an estimate on mileage.
Has anyone else dealt with this?
What are my options??
Short block?
Rings?
What is most available for these cars?
Thanks!!
Old May 9, 2013 | 09:15 PM
ZippyNH's Avatar
ZippyNH
One question...
ever change the pcv valve? Many folks have NEVER done this...thinking i might be contributing to tge fuel smell, etc if stuck.
As to everything else....just guessing a compression check/leakdown, etc before you start getting too deep...heck..could be more simple like worn valve/guides....
Know of a few close to 200,000 mile modded mini's that have been driven pretty had that run fine...so i would hope it is not the worst....
rob&JCW
Feb 13, 2023 07:03 PM
cawwwtun
May 3, 2016 08:03 AM
tr3y003
Oct 22, 2015 10:48 AM
SolCalMini
Sep 1, 2015 08:19 AM
vanhick
Aug 19, 2015 09:03 AM
