Electrical ncs expert and r56 2008
1 - sorry for my english
Hi! i search the forum but still no answer.
i had installed ncs expert and inpa and v38 and v40 daten but:
i can read adn program KOMBI module
but i can't read SPEG module, so i can't change MSA_TASTER_MEM_FUNKT
what can i do to solve this problem ?
OK! thank you!
so i repair my netbook.
i had error:
after that i installed inpa 7 and now all ok. i can read speg and other ecu
also i tried v40 daten and v46 daten
but now i don't know which datens i used to read and write speg ecu.
but as i understand v40 datens is good for this only inpa updade is needed.
Thank you!!!!
i had error:
Code:
Error in CABD! Look an CABD.err and ERROR.LOG COAPI-2000: EDIBAS orSGBD error BIP-0009: Faulty BEST version of description file
Thank you!!!!
This typically happens when you have mixed up the files from different versions of datens.
The easiest thing to do at this point is to start fresh and delete all of the files in the following directories:
C:\EDIABAS\ECU
C:\NCSEXPER\SGDAT
C:\NCSEXPER\DATEN\R56
Then install the daten files from the newest version that you have (you mentioned you have V46). To do this:
1. Copy all files in the datens ECU directory to C:\EDIABAS\ECU
2. Copy all files in the datens SGDAT directory to C:\NCSEXPER\SGDAT
3. Run the "LADEN.BAT" file in the datens R56 directory.
That should get you going. If it doesn't, then your installation may be messed up in some other way and you may need to install from scratch. If that happens, let me know - I have a much simpler installation method that I can send you to help out.
C:\EDIABAS\ECU
C:\NCSEXPER\SGDAT
BRracing
Dec 22, 2015 09:25 AM
thebordella
Aug 31, 2015 01:37 PM
skippermini
Aug 13, 2015 06:13 AM
