Electrical ncs expert and r56 2008
Old May 9, 2013 | 07:27 AM
suxo's Avatar
suxo
1 - sorry for my english
Hi! i search the forum but still no answer.
i had installed ncs expert and inpa and v38 and v40 daten but:
i can read adn program KOMBI module
but i can't read SPEG module, so i can't change MSA_TASTER_MEM_FUNKT
what can i do to solve this problem ?
Old May 9, 2013 | 08:01 AM
nutsofamily's Avatar
nutsofamily
What happens, more detail
Old May 9, 2013 | 10:37 AM
suxo's Avatar
suxo
i went to my car, turn notebook on and it's broken. good day...
but i just received error when i try to read speg, i don't remember what error, so i'll give more info later...
Old May 13, 2013 | 11:12 AM
suxo's Avatar
suxo
OK! thank you!
so i repair my netbook.
i had error:
Code:
Error in CABD! Look an CABD.err and ERROR.LOG
COAPI-2000: EDIBAS orSGBD error
BIP-0009: Faulty BEST version of description file
after that i installed inpa 7 and now all ok. i can read speg and other ecu
also i tried v40 daten and v46 daten
but now i don't know which datens i used to read and write speg ecu.
but as i understand v40 datens is good for this only inpa updade is needed.
Thank you!!!!
Old May 13, 2013 | 06:38 PM
Chernobyl's Avatar
Chernobyl
This typically happens when you have mixed up the files from different versions of datens.
The easiest thing to do at this point is to start fresh and delete all of the files in the following directories:
C:\EDIABAS\ECU
C:\NCSEXPER\SGDAT
C:\NCSEXPER\DATEN\R56
Then install the daten files from the newest version that you have (you mentioned you have V46). To do this:
1. Copy all files in the datens ECU directory to C:\EDIABAS\ECU
2. Copy all files in the datens SGDAT directory to C:\NCSEXPER\SGDAT
3. Run the "LADEN.BAT" file in the datens R56 directory.
That should get you going. If it doesn't, then your installation may be messed up in some other way and you may need to install from scratch. If that happens, let me know - I have a much simpler installation method that I can send you to help out.
Old May 14, 2013 | 01:03 AM
suxo's Avatar
suxo
now all ok - i mixed something an now all ok.
but if you pm me a link to .rar with simler installation method it will be very good
barnoun
Sep 17, 2018 05:04 PM
BRracing
Dec 22, 2015 09:25 AM
thebordella
Aug 31, 2015 01:37 PM
johntotah94
Electrical
Aug 21, 2015 01:52 AM
skippermini
Aug 13, 2015 06:13 AM
