R50/53 Torque app user
Old May 7, 2013 | 11:28 PM
scoopy's Avatar
scoopy
Torque app user
Hi torque app users would just like to ask what display are you guys using?
Im currently using the the boost, rev, speed, coolant and voltage (although im not sure if the voltage is accurate it seems it is less than 1v compared to my d1 spec and if you check with a multimeter hehe)
Old May 8, 2013 | 09:39 AM
youloze's Avatar
youloze
I've tried using a/f but it doesn't support it for some reason. Anyone know why? Works fine on my A4
Old May 23, 2013 | 07:40 AM
JP Money's Avatar
JP Money
youloze,
I think it is b/c the MINI uses narrowband o2 sensors instead of wideband ones. As the name indicates, you won't get much reading other than lean, just right or rich; with little varaince in between to give an actual reading.
Old May 23, 2013 | 07:54 AM
youloze's Avatar
youloze
Originally Posted by JP Money
youloze,
Thanks for the explanation, I didn't know that the Mini used narrowband. Seems strange for a modern car, especially for a boosted one.
Thanks!
Old May 23, 2013 | 09:10 AM
NightFlyR's Avatar
NightFlyR
I use Boost, Volts, Coolent, Speed, Revs, Air intake PSI, Intake air temp,HP,Torque, I have pictures in my gallery of different screens I use.
Old May 23, 2013 | 09:12 AM
youloze's Avatar
youloze
What info did you use to set up HP and TQ? I could never seem to get accurate readings with my A4.
BTW, I use Boost, Coolant Temp, RPM and Intake Temp.
Old May 23, 2013 | 09:18 AM
NightFlyR's Avatar
NightFlyR
Mine worked as soon as I set it up, but only when I am on the power, once you take your foot out of it, the reading goes blank for both. I am also not using the ELM adpator
Old May 23, 2013 | 09:25 AM
scoopy's Avatar
scoopy
what option is the supercharger?
Old May 23, 2013 | 09:45 AM
NightFlyR's Avatar
NightFlyR
Turbo Boost and Vacuem
Old May 23, 2013 | 10:18 AM
scoopy's Avatar
scoopy
got it so i guess your intake and intake temp you also changed the name?
Old May 23, 2013 | 10:20 AM
scoopy's Avatar
scoopy
if i may ask what volts do you get here? when you are running? and also when you are in idle? (assuming it all is on, ac/stereo/headlights/foglamps/driving lights etc)
Old May 23, 2013 | 10:34 AM
JP Money's Avatar
JP Money
Thanks!
No problem, I find it odd as well.
Can anyone down south or just near sea level confirm my boost reading of 15.3 psi near/at redline in 2nd? Ambient temp was 85-ish as per the car and intake temp according to torque was in the mid-upper 120s. Sounds right to me given the conditions but I wanted to confirm with others. Only mods are a DDM Intake and 17% pulley.
Old May 23, 2013 | 10:38 AM
scoopy's Avatar
scoopy
at wot i get 16.8-17.2 psi for my boost with 17% pulley and ddm intake and 380 injectors with miltek exhaust. not sure about my intake temp and ambient temp as i just add it right now in my app
Old May 23, 2013 | 10:47 AM
NightFlyR's Avatar
NightFlyR
I did change the names, My volts go no higher then 13.3, a low of about 12.1. My intake temp runs about 10 to 11 over outside air temp, Higher at idel but cool right down, I do have a M7 Scoop, and the M7 Airdiverter, i have seen 22 PSI on the Supercharger, which is a complete rebuild with a 15% pulley and CAI. When i was using the ELM adaptor I do not think it was as accurate as the one I have now, cause I use to get that warning message all the time, now I do not.
Old May 23, 2013 | 10:52 AM
scoopy's Avatar
scoopy
what are you using now? i'm using the elm adaptor with my s3 and i haven't gotten any warning message (hopefully i wont get any) in my app voltage i get 11.8v to 12.4 when running and i sometimes get 11.1-11.3 if i turn on all the stuffs and move my steering wheel. (at idle) i hope my alternator is not broken...
Old May 23, 2013 | 10:59 AM
NightFlyR's Avatar
NightFlyR
I was also having a low voltage and was concered about my alt, so i had it check oout and the battery, they were like new, When i was using my scan guage I also had hgher readings. I am now using the BAFX Product, it also give me when the car is cold to drivecarefully, tells me when I hit operating temps and warns me of ice. I really think the ELM was not such a great adaptor
Old May 23, 2013 | 11:07 AM
scoopy's Avatar
scoopy
you have a pic of the bafx product? yeah, i also noticed that when i look at my voltage in my d1 spec they are not the same reading in my d1 spec it is higher by 1v. though the throttle position is the same in the torque app and in my d1 spec. rev and speed are almost the same
Old May 23, 2013 | 11:11 AM
NightFlyR's Avatar
NightFlyR
BAFX Products (TM) - PIC18F2480 Bluetooth OBD2 scan tool - For check engine light and other diagnostics - Android compatible sorry for the large letters as i did a cut and paste
Old May 23, 2013 | 11:15 AM
scoopy's Avatar
scoopy
nice thanks
Old Dec 11, 2016 | 03:47 PM
caffeinatedmini's Avatar
caffeinatedmini
Hey so everyone using the BAFX
are you using the Torque app on your phone or a tablet? and does the app need to use cellular data or is everything between the app and the device.
and are you on apple ios or android?
Old Dec 11, 2016 | 06:42 PM
Andrew Riley's Avatar
Andrew Riley
So has anyone actually gotten a proper HP reading? I've been using Torque Pro for years now. Seems my MINI S is only running 18.2 HP. :D
Shocking, anyone else know of any another faults?
Fordgt4
Oct 10, 2015 10:42 AM
Sep 25, 2015 12:32 PM
ir0nhid3
Sep 18, 2015 07:52 AM
potterstein
Sep 13, 2015 09:57 PM
potterstein
Sep 11, 2015 09:24 PM
