R50/53 Crankshaft reluctor wheel
Old May 7, 2013 | 10:21 PM
Namikuz's Avatar
Namikuz
Has ANYbody seen the crankshaft reluctor wheel break apart? A large piece of my '03 S is missing and damaged the crank possition sensor in the destruction.
Wierd...... Just curious?
Old May 8, 2013 | 02:53 PM
Namikuz's Avatar
Namikuz
I CAN"T be the only one??????
Old May 9, 2013 | 04:42 AM
Namikuz's Avatar
Namikuz
Well.......... I supose that I am the only one to have had this happen..........strange.
Old May 9, 2013 | 04:46 AM
4130's Avatar
4130
Are you referring to the crank pulley? There have been quite a few reports of this. Search crank damper pulley.
Old May 9, 2013 | 05:06 AM
BlwnAway's Avatar
BlwnAway
+1, "reluctor" ?
Old May 9, 2013 | 03:12 PM
Namikuz's Avatar
Namikuz
Originally Posted by BlwnAway
+1, "reluctor" ?
Not the pulley on the front. This is what the crankshaft possition sensor gets it's reading from. It is a toothed ring that is bolted to the crankshaft inside the engine. The sensor is a Hall effect sensor,(magnet?) and as the toothed ring goes past the sensor, it fluctuates the magnetic field allowing the ECU to know where the crankshaft is in the 360 degrees of rotation. There is a 2 tooth gap to give a larger spacing for timing reference for -0- degree reference. In a nut shell.........
Old May 9, 2013 | 07:13 PM
jhiggs26's Avatar
jhiggs26
Sounds like somebody forgot to loctite at the assembly plant! Never heard/seen one break apart.
Jeremy
Old May 10, 2013 | 01:27 AM
BlwnAway's Avatar
BlwnAway
Cool, never really knew the actual name of it, always just called it the Crank Position Sensor Ring, lol.
Anyway, I have to agree, unfortunately you're the first one I've heard of with a problem.
(Edited my post, sometimes I'm just not with it, thinking Crank Sensor, picturing Cam Sensor....don't as me why.... )
Old May 10, 2013 | 05:36 AM
Namikuz's Avatar
Namikuz
Anyway, I have to agree, unfortunately you're the first one I've heard of with a problem. I wonder if someone replaced the Timing Chain & Gear and didn't re-install properly?
Crazy... I've spoken to a mechanic in Salt Lake City (my home), England and California. None have seen this before. The reluctor is towards the rear of the crankshaft and I'm the 2nd owner and the car came with a pretty complete service history. It now has 135k on the odometer.
The 3 mounting pads and bolts on the crank are still there as seen through the CPS opening, the reluctor however is broken apart.
So, I wonder what 'lil surprises I'll have once I've dismantled the engine..... Still have compression and oil psi..... So...... In to the depths I GO!!
Old May 10, 2013 | 06:46 AM
Number 7 in the diagram. Correct.
Referred to as "impulse sending wheel" by MINI. "Reluctor" is another term looks like used by other manufacturers to describe it.
Had not heard of one failing like that.
http://www.ecstuning.com/Search/11217513056/
Set to the right in the picture.
Good luck on install.
Old May 10, 2013 | 04:33 PM
Namikuz's Avatar
Namikuz
Reluctor
Mini/ BMW calls it a reluctor wheel also, see #7 from factory service manual( so I'm told this is a FACTORY SERVICE MANUAL). Nomenclature.....Eh.
Old May 16, 2013 | 07:48 PM
Namikuz's Avatar
Namikuz
end play?
Well, untill I can get the engine out and on an engine stand, I'm guessing that the crank end play is excessive and the reluctor wheel touched the block.............. Should know soon. I'll be looking for witness markes on EVERYTHING near there......
Old Dec 3, 2016 | 05:10 PM
Namikuz's Avatar
Namikuz
Well, it took 3 years but I installed a low milage '06 into Buttercup.....added an Alta 2% pulley to the crank and a couple of other little things......runs very well........
Old Dec 3, 2016 | 05:14 PM
BlwnAway's Avatar
BlwnAway
Congrats, don't feel bad, took me 3 years as well.
Sux when life gets in the way of your fun.
Old Dec 5, 2016 | 11:18 AM
Namikuz's Avatar
Namikuz
Yup... life
Life AND a dose of procrastination..
Runs really well.... JUST IN TIME FOR NORTHERN UTAH WINTER!!!!!!
Timing is every thing......
woodstudio
Mar 15, 2020 08:28 AM
barnoun
Sep 17, 2018 05:04 PM
khumpert
Nov 30, 2015 11:48 AM
Aug 21, 2015 10:41 AM
Lex2008
Aug 16, 2015 08:33 PM
