Navigation & Audio Broken USB port
Old May 6, 2013 | 09:49 PM
hoonu's Avatar
hoonu
Broken USB port
Well, I have an issue: The little plastic "divider" into which the four terminals sit broke out of the USB port in my 2007 Clubman.
Couple of questions:
1) Is the "open" side of the port to the right or to the left? It appears to (have been) to the right. I have the plastic piece, so if I can straighten the one metal terminal, I may be able to put a tiny dab of glue onto the aft end of the broken piece and slide it back in place.
2) Has anyone been behind the console to replace this terminal/port? If so, can you direct me as to how to make the repair? How hard is it to "get into" the console? It appears to be snapped, not screwed together, which doesn't bode well for trauma-free DIY repair.
All pointers appreciated.
Old May 7, 2013 | 01:42 PM
You ae taljking about the USB port that sets below the toggle in the front console?
Snaps out and then a new one snaps in.
There is one type for the :
Hands-free system with Bluetooth
or
Cell phone prep., Bluetooth + USB/audio
& another type which looks the same for
Music interface for Smartphone
Last 7 didgits of the VIN will help also with what options you have for the stereo.
Old May 7, 2013 | 03:29 PM
hoonu's Avatar
hoonu
Yup, that's it. Thanks for the info. Sorry I didn't see your post earlier.
Old May 8, 2013 | 01:31 PM
Thats ok .
Where you able to get the tab to hold. If not you can pop the old unit out and pull the 11 digit part number or give me your last 7 didgits of your Vin and the options above. Externally they look about the same , it the internals and back that are different per options.
Thanks and glad that helped.
Old Jun 21, 2013 | 07:07 PM
grimah1w's Avatar
grimah1w
I think I need same part...3.5mm aux in jack is very finicky...sometimes left channel only output from the iPhone Y cable, some times right only...if plugged in not all the way but just "right" can actually get stereo. :-(
Sending pm to you ecs if you can source this part :-)
Old Oct 14, 2013 | 10:36 AM
hoonu's Avatar
hoonu
This is an easy fix. The new part doesn't have the sliding "door" over the port that makes plug-in of the USB a pain. Suggestion: Once you do the swap, memorize which side of the plug is toward you to reduce the chance of jamming it in the wrong way.
Old Oct 15, 2013 | 11:14 AM
Did you get the part number for that?
The USB is on the left and the aux in is on the right I believe when installed, and of course when replacing the one with that option for your MINI.
Old Jan 1, 2014 | 05:56 PM
jimylegg1's Avatar
jimylegg1
Broken USB Port Question
I saw this thread and have a question.... I broke off the tip of the jack from my portable xm radio cable in the aux port side of this thing. I see that your , ( ECS Tuning) sells them. My question is, is there a tool or tip/trick to getting the old one out without damaging the dash area? Not sure how to depress that tab to get it out?
Old Jan 2, 2014 | 05:45 AM
You can depress the front on side with a little flat head screw driver, while pushing the unit out with your hand from the back. Try one side then the next.
Thanks and good luck.
Old Mar 28, 2014 | 10:28 AM
mikehotel's Avatar
mikehotel
If you have the non-usb Aux in, with just the 3.5 jack, can you pull it and swap in a USB module? I have a 09 R56 without nav/bluetooth. Maybe I'll pull it and investigate with my multimeter....Id love to buy it from you ECS ;-) vin is 3320695
Old Mar 28, 2014 | 10:42 AM
Hello Mike,
Here is the Aux in Jack version only.
http://www.ecstuning.com/Search/SiteSearch/84109237655/ES2675153/
Here is the USB , Aux for Bluetooth / Audio
http://www.ecstuning.com/Search/SiteSearch/84109237653/ES2674443/
Then the newer one for USB / Bluetooth / Smart Phone Select-able
http://www.ecstuning.com/Search/SiteSearch/84109237654/ES2703734/
Old Mar 28, 2014 | 11:06 AM
mikehotel's Avatar
mikehotel
So I have the 3 wire plug on top, L R ground...Anyway to add USB Power at least? I can soder & have electrical exp.
Old Mar 28, 2014 | 11:22 AM
Its you look at the pics the aux in only has a different plug set up vs the USB / USB select-able. You might be able to tap into something inside of it.
Old Apr 5, 2014 | 07:54 AM
tententacles's Avatar
tententacles
It was mentioned earlier in this thread that the auxiliary input socket just 'snaps out' and the new one 'snaps in'. I've been looking at it in my 2011 Mini Cooper S Clubman and I can't see how to snap it out.
I've attached a photo of the socket. I see that there appears to be some sort of access hole to the left (right in picture) of the socket, but looking down in it I didn't see anything useful. Do I just pry the socket out by working something in around the edges? Or do I need to remove part of the center stack fascia to get to it?
My AUX audio port needs to be replaced so before I ordered the part I wanted to know what I was getting into labor wise. Any tips would be greatly appreciated.
Old May 8, 2017 | 12:23 PM
aminadream's Avatar
aminadream
Hey, did you ever get an answer to your question?
gar56
Nov 15, 2016 06:41 AM
rikaro
Nov 24, 2015 02:05 PM
flpat73
Nov 2, 2015 06:38 PM
Wombat Pie
Navigation/Audio
Oct 5, 2015 08:00 PM
B1mm3r101
Oct 1, 2015 06:22 AM
