R50/53 03 r53 messed up afr
Old May 6, 2013 | 11:30 AM
dandennis123's Avatar
dandennis123
Hi I have a r53 and my afr is going lean at wot. It's running 19.0 + I can't tune it until I fix it. I've replaced the fuel filter, checked the fuel lines and checked the gas cap. It has a head with bigger valves and it's ported, sprintex supercharger, 550 injectors, dinan intake, mega mini cam, and a Detroit tuned bypass valve. Any ideas what the problem could be?
Old May 6, 2013 | 12:05 PM
Kahnfucious's Avatar
Kahnfucious
Yeah it's not tuned for all your stuff..you need someone to remap the AF maps.
Old May 6, 2013 | 12:19 PM
GreekDrifter91's Avatar
GreekDrifter91
yup you need a tune. if you have one allready it needs to be fixed but sense you didnt say you have one you need one. and its the only way it will be fixed.
Old May 6, 2013 | 12:30 PM
dandennis123
It's has a tune but it's a basic tune and they can't proceed with a better one until I figure out the problem
Old May 6, 2013 | 12:31 PM
dandennis123
And I keep fouling o2 sensors
Old May 6, 2013 | 01:06 PM
miles_miles7's Avatar
miles_miles7
Might want to stop doing WOT until this issue is fix. May i ask who gave you a basic tune for your mods?
Old May 6, 2013 | 04:49 PM
dandennis123
I have stopped wot and the tune is Mynes or bytronics
Old May 6, 2013 | 05:56 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Did you replace the Fuel pressure regulator on the rail when doing the injectors ? It has a small filtering screen and diaphragm, works under vacuum pressure maintaining the proper fuel pressure in the rail when at load.
Also, maybe you have exceeded the capability of the stock fuel pump.....those are some heavy breathing mods for a stock pump to keep up with. Dinan sold one which offered higher performance than stock.
Old May 6, 2013 | 06:10 PM
dandennis123
Dinan discontinued mini parts do you know anyone else that makes a upgraded fuel pump and a upgraded fuel presser regulator
Old May 6, 2013 | 10:29 PM
BlwnAway's Avatar
BlwnAway
I've been using the stock fuel pump for well over 125k miles with the 550cc injectors with NO issues, unless it's bad thats not your problem.
First check for a major vacuum leak, such as a disconnected line, esp. at or near the fuel regulator, the ECU will compensate for such a leak and it won't be real noticable in your everyday driving, I had a line come off after doing the VGS mod and the AFR would run about 16+ at WOT simply because the regulator wasn't getting the proper vacumm to compensate for demand.
Old May 6, 2013 | 10:35 PM
miles_miles7
^^^+ sounds like a very good advice since you did all that work to the drivetrain.
Old May 6, 2013 | 11:18 PM
dandennis123
Normal driving it runs 13 to 14 and I've checked all the lines
squawSkiBum
Tires, Wheels, & Brakes
27
Nov 19, 2024 10:26 AM
Wohnson89
Jun 10, 2020 04:53 AM
LordOfTheFlies
Oct 19, 2015 05:02 PM
bcman
Aug 28, 2015 04:47 PM
caiken
Aug 26, 2015 03:22 PM
