R50/53 Does anyone have any idea were this may be coming from
Old May 4, 2013 | 11:56 AM
R53minime's Avatar
R53minime
I tried to upload a picture from my phone but it won't work but there is a bunch of oil or something getting flung everywhere on the dipstick side and it smokes after driving for a while or hard driving but my oil lever doesn't seem to be going down
Attached Thumbnails Does anyone have any idea were this may be coming from-image-3654005282.jpg
Old May 4, 2013 | 12:00 PM
R53minime's Avatar
R53minime
Wait it did work it told me it didn't
JAB 67's Avatar
JAB 67
That looks like coolant. If so, probably a leak in the radiator.
Old May 4, 2013 | 07:01 PM
R53minime's Avatar
R53minime
It looks like oil before it dries up but I don't think oil looks like that does it it is even going up on the headlight light like its getting on the belt and flinging it everywhere
Old May 4, 2013 | 07:08 PM
ZIPPY "S"'s Avatar
ZIPPY "S"
If your oil level isn't going down is your coolant level going down? Because it looks like coolant to me as well..lol..
Old May 4, 2013 | 07:10 PM
R53minime's Avatar
R53minime
It is but we're could it be coming from?
Old May 4, 2013 | 07:33 PM
ZIPPY "S"'s Avatar
ZIPPY "S"
If you cant see it coming from a location in your car I would pressurize your cooling system...That is the easiest way to spot a leak... Sometimes by just running the car is very hard to tell where it is at.. It evaporates before you can see it.. But by the way you make it sound...it sounds like you have a good size leak..lol
Old May 4, 2013 | 07:34 PM
R53minime's Avatar
R53minime
How would I pressurize my system
Old May 4, 2013 | 07:40 PM
ZIPPY "S"'s Avatar
ZIPPY "S"
I would make sure your coolant is full and start the car and let it idle...and watch and see if you can spot anything.. But just becareful while looking...lol.. It might be a water pump.. Or the thermostat housing could be leaking.. just to name a few...
Old May 4, 2013 | 07:43 PM
ZIPPY "S"'s Avatar
ZIPPY "S"
You would have to bring it in to get pressurized.. I have my own pressurizer that I bought.. But it has come in very handy.. It looks like a over sized football pump..lol..
Old May 4, 2013 | 07:56 PM
R53minime's Avatar
R53minime
Ya but it would have to be coming from that side because all the dried up coolant or whatever is only on that side of the car
Old May 4, 2013 | 08:23 PM
ZIPPY "S"'s Avatar
ZIPPY "S"
Just guessing here...But I think it might be your water pump...lol.. So as your standing in front of the car is the leak in the front left side?
Old May 4, 2013 | 10:59 PM
ZippyNH's Avatar
ZippyNH
I am thinking if you think a coolant leak is an oil leak (very different smell, feel and look), you should 1, fill the coolant, then
2,bring the car someplace to get it looked at or fixed....
hate to be that blunt, but it sounds like you might need help beyond what an internet forum can provide. A friend who knows a bit about cars might be able to help you!!
Good luck, and please post what you find!!
Old May 5, 2013 | 07:03 AM
R53minime's Avatar
R53minime
Ya it's on the front left side
Old May 5, 2013 | 05:16 PM
ZIPPY "S"'s Avatar
ZIPPY "S"
That's why I feel its the water pump... Its in that location.. plus that tends to be a common thing to go out..lol.. Now with that said that does not mean at all that it is the water pump...It could be anything.. The best thing for you to do is have it looked at.. Because your still not sure if its oil or coolant.. Plus I don't know how much you work on your own cars when it comes to this type of thing.. Ive been working on MINIs for awhile now..with out seeing it..it would be wrong for me to tell you forsure what is wrong with it.. If you have any questions I would be more then happy to give you ideas of what it could be.. It would be up to you to verify the problem.. Good Luck and keep us posted
Old May 5, 2013 | 05:47 PM
JAB 67's Avatar
JAB 67
I must differ with 'ZippyS'. That clearly looks to me as if it is near the pulley end of the supercharger; water pump is at the other end.
Old May 5, 2013 | 05:53 PM
ZIPPY "S"'s Avatar
ZIPPY "S"
That is my fault.. I should ask if you are talking driver side or passenger side so I don't get confused myself.. JAB 67 good catch on that! Thanks!!!
Old May 5, 2013 | 05:59 PM
ZippyNH's Avatar
ZippyNH
Since the end of the radiator hose IS just in the edge of the picture...it might have chafed, or have a small leak....feel around...look around. Changing a hose is easy...but bleeding a gen1 mini is a pain once it hasgone low on coolant....
that and i bet you car might be overdue for a full coolant change..THE MOST overlookeditem in mini mx. Next thing....look at the radiator....they can leak on mini's where the plastic is crimped onto thr metal part...all modern oem rads are built like this....aftermarket copies are $85-90, oem is like $300+.
Old May 5, 2013 | 07:25 PM
R53minime's Avatar
R53minime
That's the thing I do all my own work I just put on a 17% pulley and dt bpv I just got done taking a motor out of a civic and putting a new one in I can fix whatever it is I just can't find where it is coming from
Old May 9, 2013 | 06:35 PM
R53minime's Avatar
R53minime
It ended up being my radiator it was leaking were they crimped the plastic on and just blowing off while driving which also explain my coolant level going down I ended up ordering a mishimoto radiator just got it today thanks everyone for the help!
Old May 27, 2013 | 05:06 PM
R53minime's Avatar
R53minime
Got my new mishimoto radiator in
Attached Thumbnails Does anyone have any idea were this may be coming from-image-4196251328.jpg
Old May 27, 2013 | 05:58 PM
uromini's Avatar
uromini
That looks great in there..
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
scottrn
Aug 22, 2015 07:26 PM
Shane Wendel
Electrical
Aug 20, 2015 06:50 AM
Razor2015
Aug 6, 2015 05:27 AM
