Is this setup possible?
Old Apr 30, 2013 | 09:43 AM
ramiroc19's Avatar
ramiroc19
Found these wheels for sale and would like some help to see if it is possible to run. The wheels are 5x114.3 but will run adapters. the specs on the wheels are 19x8+8 front and 16x9+15 rear.
Old May 1, 2013 | 10:46 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Will the wheel adapters serve as wheel spacers? If they do then they may cause the wheels to stick out even more.
What tires were you planning to use? Sizes?
19x8 et8 in front would stick out 2.2" farther than stock so you would need a wide fender arch added.
Michelin Pilot Super Sport comes in 235/30-19 but fits rims 8.5" wide and doesn't come in any 16" sizes for the rear wheels.
225/35-19 would fit the 8" wide rim but is tall at 25.2" tire diameter, leaves less clearance and looks oversized.
The rear 16x9 et15 rim will stick out 2.1" more than stock, again a wide fender arch would be needed. What tire size? 245/45-16?
Fuzion ZRi tires? Comes in 225/35-19.
Overall in my opinion these wheels are not worth considering, not to mention wrong bolt pattern.
Old May 2, 2013 | 04:00 AM
Creeve's Avatar
Creeve
I'm guessing this is a typo and the OP actually meant 16x8 et8 and 16x9 et15.
Doesn't matter either way though these won't work unless you want to run tons of camber and go for this look:
Old May 2, 2013 | 05:05 AM
Braminator's Avatar
Braminator
^^^^This IMO is just dumb. ^^^^ Please can someone tell me why they think this looks good?
Old May 2, 2013 | 05:55 AM
Creeve's Avatar
Creeve
No one said they think it looks good.
Old May 2, 2013 | 06:02 AM
Braminator's Avatar
Braminator
Thats why asked for someone to tell me why it does. LOL
Old May 2, 2013 | 06:12 AM
Creeve's Avatar
Creeve
This is the other option if you don't like camber
Old May 2, 2013 | 06:21 AM
Braminator's Avatar
Braminator
That is much better but needs wider flares IMO.
Old May 4, 2013 | 12:45 PM
afadeev's Avatar
afadeev
... and massively raised suspension with massive mud tires to complete the swamp monster look ...
Old May 4, 2013 | 12:47 PM
afadeev's Avatar
afadeev
*Please* pass on these and keep looking.
The size and offset are somewhere between comically WAAAAAayYYYYY wrong and wont fit at all.
IQRaceworks
53
Jun 28, 2024 07:29 AM
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
minimofo
Dec 26, 2015 12:03 PM
Suspension Products
Oct 1, 2015 11:53 AM
