Suspension How Strut top nut works?
Old Apr 29, 2013 | 08:20 AM
johntotah94's Avatar
johntotah94
Sorry guys. I know I may sound dumb but I am an ametaur with this stuff. How does the nut on the top of the strut work.
I know there is a hex bolt. What is it for? How do you losen and tighten the top of the strut? Thanks!
Old Apr 29, 2013 | 08:25 AM
xsmini's Avatar
xsmini
Use a hex wrench to keep the strut from spinning and then use a socket to tighten or loosen. Use a socket that you can use a box end wrench on (i.e. spark plug socket), then run the hex through the center of the socket. They have special tools, but backyard redneck tricks work too.
Nik
Old Apr 29, 2013 | 08:27 AM
johntotah94
Nik
Cool. So when you losen and tighten you need the hex key to hold it down? Or only to losen?
Old Apr 29, 2013 | 08:28 AM
xsmini's Avatar
xsmini
Both, keeps the strut from spinning.
Nik
Old Apr 29, 2013 | 08:35 AM
johntotah94
Nik
Ok. I'm just trying to figure out how it's possible to torque down the nut when you need the hex key in.
Old Apr 29, 2013 | 09:18 AM
countryboyshane's Avatar
countryboyshane
I'm not sure if 21mm is the size of the stock top nut on the strut, but these are a huge help.
http://www.eurosportdesign.com/p-438...FUJa4Aod7zQAgg
That way you can sneak your wrench or allen key inside the socket to tighten things down properly.
If you don't want to buy one, you could always buy a sacrificial socket and use a cut-off wheel to make one. That's what I did to make mine.
Old Apr 29, 2013 | 09:45 AM
Fastlane's Avatar
Fastlane
To set the proper torque for the top nut (I don't recall the torque setting), put the hex key bit on your torque wrench set to reverse and tighten the nut with a wrench. That's the way I did it.
Old Apr 30, 2013 | 06:40 AM
blakeslee_a's Avatar
blakeslee_a
BMW uses a specialty socket for this, as other people have said you have to hold the inside but while spinning the outer to tighten. I just installed my coils and instead of buying a $50 socket from mini I bought a 21mm deep socket and use a hand grinder to cut a hole in it, a spark plug socket would also work but I wanted to cut a hole in some for fun haha
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
Dec 23, 2015 10:36 AM
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
minipopkart
Aug 13, 2015 05:22 AM
