R50/53 Squeaky Windows
Old Apr 22, 2004 | 11:35 AM
chollomo's Avatar
chollomo
I had squeaky windows for awhile when I open and closed the windows, I then took them into my dealer and he said their lubricant was "dry" well now they're both doing it again? pretty crazy. Any idea why this is reoccuring? argh! Anything? I can do without having to take it back in to the dealer.
Old Apr 22, 2004 | 01:27 PM
lotsie's Avatar
lotsie
Every time I open my windows they maka a differnt sound wind ,dry glass ,cold ,hot, wet ,,but they do make noise ,if we had to hand crank would they make any noise
Old Apr 22, 2004 | 01:29 PM
d2mini's Avatar
d2mini
Mine do it when it's hot out and it's been sitting outside in the sun.
Only the drivers side.
Gonna have the dealer take a look at it on monday when they install my roof rack.
Anyone know how to access the window mechanism??? :???:
Old Apr 22, 2004 | 01:41 PM
GJR's Avatar
GJR
Mine does the same thing. Quiet all winter, but now that it's getting warmer out, it's back. My dealer has nothing to remedy this except to suggest using silicone on the seals (which does not solve the problem).
Old Apr 22, 2004 | 02:07 PM
chollomo's Avatar
chollomo
mine did it in the cold AND in the heat.. though it may even be worse in the heat.... oh well, it nto liek I'm rollign them up and down all the time, It just as bad as someone pulling theit nails down a calkboard tho.
Old Apr 22, 2004 | 02:42 PM
Antranik's Avatar
Antranik
Mine squeaks ridiculously after any wet weather, including car washes.
Old Apr 22, 2004 | 02:58 PM
Sweetmini_03's Avatar
Sweetmini_03
looks like this may be a pretty big problem, i know mine do it to on both sides pretty bad. the driver side vibrates sometimes when it does it i think the rail the sit in was porly designed. hrmm mabey a recall is in order to replace them?
Old Apr 22, 2004 | 03:05 PM
lotsie's Avatar
lotsie
>> looks like squeaky window gets a thread
Old Apr 22, 2004 | 03:13 PM
OctaneGuy's Avatar
OctaneGuy
Only my driver side window squeaks, but I'm wondering if it has anything to do with usage. I rarely open the passenger side window.
Old May 7, 2004 | 02:13 PM
seanandcandace's Avatar
seanandcandace
Mine both squeak. They sound a lot like when you run a squeegee (sp??) across a window, which doesn't surprise me since the squeak comes from the rubber gasket. It wasn't bad in NYC (where it was cooler), but now in FL, it's much louder. It's annoying, but not nearly as annoying as not being able to see traffic lights when you are the first one in line or having sun visors that are too small to block any sun. :smile:
Old May 7, 2004 | 02:19 PM
D.J.'s Avatar
D.J.
Hey I think what all of you folks that have the squeaky windows problem is..is that your windows may be too clean
Man I miss California
Old May 7, 2004 | 02:29 PM
theWrkncacnter's Avatar
theWrkncacnter
The only time my windows squeak is when I roll them down right after I wash the car. So maybe the poster above has a point.
Old May 7, 2004 | 02:59 PM
DOGHOUSE's Avatar
DOGHOUSE
Mine only squeak when it is hot outside and the car is in direct sun light. I hate the sound because it makes me think the window motors will be breaking at 50,001 miles
Old May 7, 2004 | 03:26 PM
MEmini's Avatar
MEmini
My driver's side window squeaked and then one day I got 3 vertical cuts in the window glass. The mechanism had failed. Dealer replaced window and mechanism with NO questions. Hmmm....
Old May 7, 2004 | 03:27 PM
MaxaMini's Avatar
MaxaMini
Both sides here. I attributed it to the Tints but coincidently that was done recently with the warmer weather. I'll check the sound in both wet and dry as well as temperature variations.
Old May 7, 2004 | 08:37 PM
indygomini's Avatar
indygomini
I would definitely recommend taking the car in to the dealer and getting the window noise checked. My driver's window also sqeaked and squealed during up and down travel on warm or very sunny days. It took replacement of the window motor and regulator assembly to cure the symptom. The long version of the story is here:
https://www.northamericanmotoring.co...mp;topic=25146
If the window squeaks with the door open, that eliminates the door edge seal as the culprit!
_________________
Midnight- '03 indi blue MCS, learning all the bad habits of a proper British car from Rusty- '75 MGB
Old May 7, 2004 | 09:07 PM
OctaneGuy's Avatar
OctaneGuy
Old May 8, 2004 | 12:14 PM
02s79fj40's Avatar
02s79fj40
"window lubricant" thats nice. In my book thats about the same as halogen fluid and muffler bearings. The regulators and motors shouldn't need lubricating for a LONG time. That said, my 02 has had the drivers side regulator replaced twice now. Once cause it squeaked, second for rattles.I don't think it's a lube problem, it's a design problem. These cars were rushed to market. Don't get me wrong, they are an absolute blast to drive, but the interior build quality is on par with the finest hyundais and yugos of the mid 80's. I've got 4k left on my bumper to bumper warranty, what to do? And my sunroof is rattling again, and i've got the stumble big time, and the gray finish is peeling off the leather on my driver's seat.
Old May 8, 2004 | 11:05 PM
namwob's Avatar
namwob
These are professional dealer mechanics, they don't make money lubricating stuff, and its not their personal car. You want to drive an '81 (pick a car you detest)_______ for a week ?
Fix it yourself its easy. mikemike
http://www.cooperspeed.com/forums/showthread.php?t=338[img][/IMG]
Old May 9, 2004 | 05:50 AM
theWrkncacnter
Speaking of windows, anyone ever have the problem of the window not going down just a bit when you open the door. Mine were doing that the other day and I couldn't shut the door without the window going on the outside of the gutter.
Old May 9, 2004 | 06:12 PM
Pebbles's Avatar
Pebbles
This happens to me ! I have to get in and start the car with the door open, then bring down the window and then close the door, then I put up the window and cut the car off. I then tell Mr Bridger off, usually something about him not giving me any bloody crap and when I opened up the door to get out, it worked correctly....
I have found cussing works!
Actually, I believe it's something like rebooting your computer. I cut the car off and when I restart him, he's got it all sorted out and knows what he's doing. It even worked when he made the hatch light stay on when the hatch was closed, I have found I just pull over, cut off the car, restart the car and it's fixed.
USNAE2
16
Jun 17, 2022 07:17 AM
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
semibreve42
Oct 2, 2015 09:06 AM
rt808
Sep 25, 2015 01:59 PM
