SS Brake line question!
Old Apr 26, 2013 | 06:25 AM
sprp85's Avatar
sprp85
Hey all,
I just have a quick question regarding braided brake lines.
I bought a set a couple years ago thru GB and they've been sitting around up until now..
My car is 05 R53 and my plan was swap the lines out when I was doing R56S conversion up front..
Since I have a track day coming tomorrow, I figured I would get at it after work today..
So I was looking around to gather more info on this job but noticed how some people mention the rears are banjo fitting..
I believe they were changed to straight-male fitting on later year cars? (My car is at my brother's house so I couldn't visually check)
The contents I've received from the GB are as follows:
4x SS Lines (Male fitting, Screw in type - Confirmed fitting with R56S calipers)
4x Copper washers
Well here are my questions:
1) 2005 R53: Rear lines, Banjo or male-screw in type?
2) I have 4 copper washers when theres no banjo fitting lines. What's going on? Am I suppose to use em on the caliper or at the point where hard hydraulic lines meet? or was it sent out as a mistake?
Please lend me a hand here!
Thank ya'll in advance
Old Apr 26, 2013 | 06:53 AM
Braminator's Avatar
Braminator
MINIs with production dates in or before April 2003 have a banjo fitting where the rear hose attaches to caliper.
MINIs with production date of May 2003 and later does not have the banjo fitting at the rear caliper - threads directly into caliper.
Old Apr 26, 2013 | 07:03 AM
sprp85's Avatar
sprp85
That's what I needed
Any idea on why the seller included copper washers?
Old Apr 26, 2013 | 07:10 AM
Braminator's Avatar
Braminator
Because they crush and seal the hose to the caliper. Without them they can leak.
Old Apr 26, 2013 | 07:34 AM
sprp85's Avatar
sprp85
Ah,
So even straight fitting lines need washers for seal ?
Thank you
Old Apr 26, 2013 | 07:41 AM
Braminator's Avatar
Braminator
Yes, and make sure you get the old one off if it is stuck on the caliper.
Old Apr 26, 2013 | 07:46 AM
sprp85's Avatar
sprp85
Perfect. Mysteries solved
I will tackle it today and see if I can get it done
Thank you again
W0TM8
Dec 19, 2019 07:50 AM
ebowling
90
Aug 4, 2019 09:15 AM
minimofo
Apr 4, 2016 07:36 PM
minimofo
Dec 26, 2015 11:45 AM
StealthR53
Aug 8, 2015 10:59 AM
