R55 wiper blades
Old Apr 25, 2013 | 06:37 AM
John A Shook's Avatar
John A Shook
wiper blades
Does anyone recommend specific replacement wiper blades that last longer than 3 months without chattering on the glass? To include rear blades because I have an 08 Clubman justa. Any recommendation will be greatly appreciated.
Old Apr 25, 2013 | 07:04 AM
Capt_bj's Avatar
Capt_bj
try cleaning the glass really really well
clay bar and or razor blade.
when my blades drag and chatter, I clean the glass this way and usually all is well. I change blades less than once a year and have used OE at times - PIAA also
Old Apr 25, 2013 | 01:43 PM
pmsummer's Avatar
pmsummer
Glass chattering with blades that are good is usually caused by something on the glass, as Capt_bj mentioned. If you have your car "waxed" at a drive-through car wash, there's your culprit (or wash it yourself at a car wash and use the spray "wax").
Clean your windshield well with rubbing alcohol, and that may solve your problem!
BTW: Out Motoring sells the rubber inserts for MINI wiper blades. Takes a little work, but it's keep your OEM MINI blades, and saves you money. As for aftermarket blades, Michelin blades have served me well, as have Bosch and ANCO.
Old Apr 25, 2013 | 01:48 PM
Capt_bj's Avatar
Capt_bj
the first time you use a window scraper (old school)
or clay on your glass you are going to be amazed what window cleaner was leaving behind
in much the same way as when you first clay the paint
I use rain-x too
Old Apr 25, 2013 | 02:52 PM
Kirby11's Avatar
Kirby11
Here's an interesting video on chatter caused when blades are a little bit bent out of alignment. Since it sounds like you're having chronic chatter problems it might be worth checking out.
Doc Pain
Mar 10, 2021 04:50 AM
PsychoRallye
21
Feb 17, 2019 06:08 AM
Scm68
Jan 27, 2016 12:33 PM
Samhillrocks
Sep 29, 2015 12:55 PM
Sep 3, 2015 12:24 PM
